Posted on Mar 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Recording to Cassette
Instructions for recording unclear, especially from radio.
Anonymous
Level 3:
Brigadier General:
  • Master 6,966 Answers
  • Posted on Mar 23, 2008
Anonymous
Master
Level 3:
Brigadier General:
Answers
6966
Questions
17
Helped
3089085
Points
19604
Most Audio Shelf System follow the same procedures for recording. You need to select your source as if you will just be listening, AM, FM, Aux etc. Thereafter, you need to press Record (sometimes with PLAY) to start the recording. Normally, it will record whatever source is playing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
I have an nostalgic music combo model #9397. All the components -turntable cassette radio cd work. But it won't record in any mode. Any ideas?
I'm assuming you mean the cassette won't record?
At the top of a cassette are two slots - one either side of it. If these are open then the record button can't be pressed. You can cover them with sticky tape to allow recording. If these are not open and you can't record, then sometimes the lever that presses against them is bent or broken stopping recording.
How do I set up my jvc_td309 double cassette deck for recording on cassette tapes? Also what settings?
Adjust recording bias, if one, for the kind of tape you are using and you are good to go. For best performance use the brand of tape that was used to set up the machine when made.
If you have a fine tuning control for the bias, use it per instructions for best frequency response and s/n ratio.
How to erase a recording on a Sony TCM-150 cassette recorder?
Just press the record button. Also make sure the cassette is not write protected.
I cannot get my RCA Boombox Model no.RCD150 to record. Is there a trick to recording?
No trick. Did you follow the manual's instructions? What DOES it do instead? Are the erasure-prevention tabs missing from the target tapes? See page 14.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RCD150-Boomboxes-manual/id/402ci674/t/2/
When recording it shows that it is recording but we can't see anything. If we play back what we think we might have recorded we can only hear the sound but not see anything.
Follow the steps below to troubleshoot this issue.
IMPORTANT: If additional model-specific instructions are needed to perform any of the steps below, refer to the operating instructions of the camcorder. The instruction manual is available in the Manuals/Specs/Warranty section of the Sony eSupport Web site.
  1. Ensure a fully-charged battery is inserted or connect the AC power adapter.
  2. Turn the camera on to the VTR or PLAYBACK mode.
  3. Insert a cassette tape with recorded video into the camcorder.
  4. Ensure the cassette tape is rewound to the beginning of the video recording.
  5. Begin playing the cassette tape.
  6. If your camcorder has an LCD screen, try adjusting the brightness or contrast.
  7. If there is still no picture on the LCD or viewfinder, reset the camcorder to factory specifications
Records on right channel only so only get music from right speake
If you are recording from an outside source check the connections are good. If it does it from both IE dubbing and external it is possibly that a wire has detached from the head of the record head. The other likely source is the record amp inside the deck. Trace the leads from the Tape head (recording one) and see if you can locate a switch, these can get dirt on the contacts and cut out channels (clean with Servisol video 40). It could also be the electronics especially the amp chip!
If not then the head itself may have gone.
2answers
Recording button can't be pushed down any longer
1. PlayStation 2 systems do not handle tapes, but CDs and DVDs. No wonder you have broken it if you inserted a tape in it.
2. There is no radio in a PlayStation 2 system.
3. On a PlayStation 2 system, the button with a red dot on it is the power button, and it turns green when the power is on.
4. You cannot record, especially not on tapes, with a PlayStation 2 system.
5. You usually don't play a PlayStation 2 in the kitchen, but in the living room since it's meant to be plugged in your TV.
Here's the diagnostic : you do not own a PlayStation 2 system.
You have been ripped off by whoever sold you this piece of **** under the name of "PlayStation 2 system".
I have a Stereo Double Cassette Deck; Pioneer CT-W404R. I've set the REV MODE switch; I've pressed the record button; I press playback and the tape for recording begins moving, but not the other tape. If I...
I was following instructions for "Recording." On the next page were instructions for "Tape Copying," though the first page began with, "Load a tape for recording in Deck II." That sounded like what I wanted. Anyway, that was my error.
1helpful
3answers
 Grubhead
Grubhead
SmartAviator
SmartAviator
