Question about Tissot T-Touch T33759851
The time and hands are not in sync...how do you fix issue?
  • 299 Answers
You can download the manual for the setting instructions from here: http://support.tissot.ch/
Posted on Apr 25, 2010
How to sync. an old Black Forest cuckoo clock.
Suppose the cuckoo is calling three and the time is showing eleven, then to synchronize, simply stop the clock till the time is the same as the bird (three) and restart the clock at that time.
If the error persisys, then pull off the hour hand, and replace it at the synchonized time.
Jul 13, 2012 | Watches
How to syncronize time with clock chimes? Howard Miller banjo clock.
The hands on your clock are probably friction fit, meaning that they can be adjusted, possibly even without tools. The hour hand is usually a firm slip fit over a tube, meaning that it can be slid forward and backward an hour or more as long as you hold the minute hand steady to keep the hour shaft from turning.
The minute hand may be trickier to adjust. Sometimes, it, too, is a simple friction fit, and you can pop off the hand (remove the second hand and pull the minute hand straight up off its shaft) before setting it where it should go. Other times, however, the minute hand is on a keyed shaft and has to go on in one of two directions. It's still possible that someone could have assembled your clock incorrectly, however, making the minute hand 30 minutes out of sync with your chimes.
If neither of these ideas helps you, please describe better exactly how the time isn't matching up with the chimes. That will help us better understand the underlying issue.
May 09, 2011 | Watches
This is a dual time watch and the minute hands are not in sync. How do I open the crown on this model to access the hands.
It honestly depends on the model. If the model is a dual movement model, there is usually a crown at the 3:00 and 9:00 positions on the case. You would want to:
1) Pull each crown out when the second hand is at 12:00, if there is no second hand, then the minute hand should be over the next 1-2 minutes for proper syncing.
2) go to: http://www.time.gov/ , select the proper time zone(s) that you would like to sync to.
3) Count down to the next minute time change, and simultaneously press in the crowns on both sides, engaging the hands to the movement.
If this is a different model than what I have described, please describe the watch brand, model, and buttons / features that you see, and I am happy to help!
Feb 04, 2011 | Watches
Hands and LCD are out of sync
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TISSOT watch manuals.Rate me, please
Mar 26, 2010 | Tissot T-Touch T33759851
Hands won't sync up
It sounds like the time zone may be incorrect; check your manual to see if this can be the case. Also, these devices may wait until some time between midnight and 3 AM to synchronize with the 'atomic' standard. Make sure you have the watch near a window as this may aid reception depending on where you live.
Mar 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I cannot get the first and second hands to reset
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CITIZEN watch manuals.Watch for INTERACTIVE SETTINGS there. Rate me, please
Mar 14, 2010 | Citizen Blue Angels Skyhawk Watch
Our wall clock was not wound a couple of months ago (it is a chime clock that chimes on the hour and half hour with weights) and when we rewound it, everything works fine except that the chime is out of...
You were not very specific about you clock description, Many of the German clocks were using auto correct features.
You may not have this function.
Move the hour hand to the correct hour.
Hope this tip help you.
R/
David
http://antiqueclock.clockstop.com/
Mar 13, 2010 | Watches
Setting my Tissot touch Navigator 3000
Per the manual: http://support.tissot.ch/usersmanual/140-en.pdf
When your battery begins to die, the hands are no longer synced.
After replacing the battery, go into local time mode (pressing the center of the crystal) until "Set" appears. Press the crown. Scroll to "ECO BAT", press and hold the crown for 5 seconds until "SYNCHRO" appears. Use the "+" button to move the minute hand and the "-" to move the hour hand until they are in the upright or 12:00 position.
Either press the crown again or wait until the watch automatically leaves the Set mode. Your hands should now represent the local time.
Feb 08, 2010 | Tissot T Touch Navigator 3000 T96.1.478.32...
Seconds out of sync on waveceptor
Hi!
press the lower left button until "H-S ET" appears, then press upper left button for 3 seconds ("-0 0-" appears on the screen), press lower right button for adjust the seconds hand
Nov 29, 2009 | Casio Watches
Tissot T-Touch T33759851 Logo
200 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Mohamed Ismail
Mohamed Ismail
Are you a Tissot Watch Expert? Answer questions, earn points and help others
