Question about GE Microwave Ovens
New smart board installed in microwave, still doesn't work
A service tech told me the smart board in the GE over the range microwave was bad, so I got another one and installed it and it still doesn't work. The installation seemed pretty simple, what could be wrong? Can I test if a smart board works without an electrician?
  • GE Master
  • 9,047 Answers
It sounds like he "shotgunned" and blamed the board without experience enough to know the difference or to test it.
We would need to know what exact problem you're having and what your full model number is.
Feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Apr 28, 2010
Keyboard shortage
The keypad control board or smart board needs attention," membrane in keypad is shorted"
Mar 27, 2012 | GE Spacemaker 1.5 Cu. Ft. Over-the-Range...
Range lights on a over the range GE mirco wave won't work. The touch pad works and says the lights are on but no lights
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
Or you can buy and install a new control circuit board (smart board) from the Pros here, our favorite supplier.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
Oct 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave JVM1851WD001, buzzes if you open the door, buzzes if you push any buttons but will not start. The light is on if you open the door and the digital clock is working.
That is a control circuit board issue which we regularly repair with our $39.95 service nationwide.
Or if you prefer, you can order a new smart board / PCB assy (part number WB27X1043) from the Pros here, our favorite supplier. It runs $259.53.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Have a GE Hood micro model # JVM1540DN1WW. Control panel doesn't work. Did hard reset buy cutting power. Probably bad smart board. Problem is this is the 2nd one I have had . These last only 2...
You have a failed membrane keypad.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB56X10824 and you can order it here for $124.12.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site ,we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame. Be careful - the display is made of glass.
Some connectors on the relays may have a lock:
May 24, 2011 | GE Spacemaker JVM1540 Microwave Oven
Vent button will not start fan, but boost button will (only on a very high speed.) Seems there's an overheating problem with these GE Cafe microwaves. Is there a retrofit kit available?
It may be a bad fan button or a problem on the circuit board. The latter is actually cheaper to fix.
If you recently had trouble with your cooktop lights, the fan trouble is probably due to that. It's a failure on the smart board which we regularly repair with our $39.95 service. Details are here.
If it's a broken button, and yours is a CVM2070-series model, GE sadly does not make separate parts available, so you would have to order a new "control panel subassembly".
Jan 23, 2011 | GE CVM2072SMSS Microwave Oven
Microwave won't heat food, new smart board unavailable?
HAVE YOU THOUGHT ABOUT TRYING TO BUY A USED ONE AND TAKING THE BOARD FROM THAT ONE AND PLACING IT IN YOURS ?
Apr 13, 2009 | Microwave Ovens
Microwave Range lights are out.
yes ,it is the internal board that unfortunately controls most of the functions on this microwave , but if its still under warranty your safe ,if not you can still call customer service of the manufacturer and let them know it has never worked and they will probably send you the part free of charge , hope this helps , sincerely glenn
Mar 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Fan and Lights do not work
Sorry a bad controller printed circuit board or what GE calls a smart board. I have seen these smart boards as low as 85 bucks, go up to a price of 179.00!
Sep 18, 2006 | GE JVM1651 Microwave Oven
Microwave Ovens Logo
110 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
