Question about Dometic RM2852 Refrigerator
Installed used fridge and no power - Dometic RM2852 Refrigerator
    Sergeant:
  • 239 Answers
Make sure your circuit braker is on
Posted on Apr 25, 2010
I have a Dometic fridge model number RM2612 in a camper that i just purchased used and the fridge isn't cooling. The freezer section seems to be okay. The metal plate in the freezer gets cold but
Make sure it is level, has proper airflow out through top vent. Also check baffle, or stack where flame sits under and blow it out good with compressed air to make sure it's clean. If you smell a hint or strong smell of ammonia, shut it off, it has a leak in cooling unit. If all ok in that area, shut it off, disconnect and plug propane line, disconnect power and remove the fridge. Turn the fridge upside down for a day or 2, then re-install and let it sit 24 hrs before turning it back on. Quite often that will take care of any blockage in flow of cooling liquid, and get things back to normal if cooling unit is still good.
May 22, 2012 | Dometic RM2620 Refrigerator
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    Samsung fridge rs52530bwp the fridge side will not work
    I have a similar situation before in your case if your heating element is working then you are lucky I had a samsung fridge and the defrost heating element was bad and i was forced to install a different one because i would have to change the hole evaporator in order to replace the heating element so what dit was to use a mechanical 10 hour defrost timer and install a generic heating element and a defrost thermostat on serial so it want work on less the evaporator has froze over i drill a hole to the back of the fridge and i wren the cables to the back of the fridge cover then whit foil tape an take power directly from the power cord i install the timer next to the control board so every 10 hours will give power to the heating element but will not come on unless the evaporator has froze up. on my case i had to do it like that because the heating element i use was to strong for the control board and would just burn it up. but will work even better using the original heating element. NOTE: find the diagram of a old fridge that will help you to figure out how to install the timer and the defrost thermostat no need for the timer to cut off the compressor keep in mind than the defrost thermostat only close the circuit when is chill below freezing so i recommend to use a new one I hope this help you
    Jun 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
    Dometic fridge inop on A.C. power
    There is a fuse at the back of the fridge located near the compressor. You've done quite a bit of checking, so rathe than try to get into stuff, here's some quick info and a link to the manual for your fridge, which should help.
    The control switches have to be set a specific way depending on what source is being used and the thermostat turned on when using AC power. Check item #3 Operating Instructions on Page 6 and the control panel switches on Page 9.
    Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
    http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
    Possibly the installation instructions will assist in determining how it was installed in your RV, but usually the installers build around stuff, so you might have to remove some trim in order to get the fridge out, etc.
    Hope you find this helpful and will you resolve your issue.
    Jun 09, 2009 | Dometic RM2193 Compact Refrigerator With...
    RM4236 tripping site electrics
    Paul;
    Are you tripping the shore power pedestal? If so did you unplug the fridge and try it. The park pedestal breaker should be at least 30 amp and I can not believe the fridge would trip the site breaker before it tripped the breaker in your caravan. Are you sure it is the fridge? Your fridge is an old eletrolux dometic and I can not find the manual in my files. You may call Dometic and get a manual but That will not help you much. I will be more than glad to resolve your problem but I need more info.
    The Dometic# is 800 366 3842. Prompt to tech dept.
    Repost to us
    Thank You for using Fixya
    Jerry
    Mar 26, 2009 | Electrolux Refrigerators
    Looking for fridge
    I will contact the people in Namibia as I still have their contact details.
    Jul 09, 2008 | Refrigerators
    Fridge stops working when power goes out.
    Good possibility that the electrical contacts have failed (burned/welded) in either the defrost timer (part# 68233-3) or the Cold Control (part# 61002085. An intermittent failure is extremely difficult to track down. Both of the parts I listed total about $80. You can purchase them and install them for less $$ than having a professional do it for you. We would obviously charge more because we would absorb the cost of warranty, labor, drive time, etc... If you choose to replace these components, UNPLUG THE FRIDGE BEFORE HAND!
    Jul 29, 2007 | Magic Chef CTB2125 Top Freezer...
    Dometic RM2852 Refrigerator Logo
    66 people viewed this question
    Top Dometic Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    4stevetaylor
    Level 1 Expert
    Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
