Question about Intel D845GLLY Motherboard
What is the biggest processor i can put in - Intel D845GLLY Motherboard
  • 22 Answers
To show me how to break the number 127 to binary form
Let's start by setting up the binary columns.
2^0 = 1
2^1 = 2
2^2 = 4
2^3 = 8
2^4 = 16
2^5 = 32
2^6 = 64
2^7 = 128
Written horizontally.
128 64 32 16 8 4 2 1
1 1 1 1 1 1 1
What is the biggest number that goes into 127. 64. Put 1 in the 64s column. 127 - 64 = 63.
What is the biggest number that goes into 63. 32. Put 1 in the 32s column. 63 - 32 = 31.
What is the biggest number that goes into 31. 16. Put 1 in the 16s column. 32 - 16 = 15.
What is the biggest number that goes into 15. 8. Put 1 in the 8s column. 15 - 8 = 7.
What is the biggest number that goes into 7. 4. Put 1 in the 4s column. 7 - 4 = 3.
What is the biggest number that goes into 3. 2. Put 1 in the 2s column. 3 - 2 = 1.
Put a 1 in the 1s column.
So we have 1111111 in binary.
Good luck.
Paul
Oct 02, 2014 | Office Equipment & Supplies
Food processor assembly
I'm going to take a guess that you can't get it to work....tell me if I'm wrong. The biggest mistake people make when assembling their food processors is putting the bowl on backward. It will not run if the bowl is on backward. The handle on the bowl should face the front of the base. Once you click that into place, put the blade on, then lid and lastly the pusher. For safety reasons, all of that has to be in place for it to work.
Jul 18, 2012 | Cuisinart DFP-3 Handy Prep 3-Cup Food...
I'm looking for the capacity of this motherboard like what is the biggest processor stuff like that
try this one. There is absolutely nothing other than sites where you can buy an IBM motherboard, I even searched the IBM site. I did find this link as IBM systems often use INTEL motherboards but are referred to as IBM boards.
If the components line up properly this is your board.
http://downloadmirror.intel.com/15322/eng/D845G_Boards_TechProdSpec.pdf
Nov 11, 2011 | IBM (03R0329) Motherboard
How to make a gaming PC? what model of computer parts should i buy?
1 find motherboard set up for gaming,{im using nvidia 750i sli xfz, with 750 watts power supply,,intel 2core 2.4 processor, 4 by 1 gigs ram nvidia gtx 8800 graphics card the biggest processor cooler you can fit,plenty of big fans for cooling and i can play far cry 2 lovely , ] GET similar spec items and should be okay
Jul 07, 2010 | Computers & Internet
My gateway G6-350 supports a second processor...how may i determine which processor to buy as second one...must it be the same one...thank you for your time
hi,
according to gateway 450mhz is the largest that can be put into your system. The biggest performance gain will be found in a RAM upgrade. The difference between a 350MHz & 450MHz CPU will be minimal & maybe not even noticeable. But if you already have another CPU or can pick one up for a few bucks, it wouldn't hurt...I wouldn't spend more than $5 though.
Your best bet would be to try to determine the make/model of the motherboard, then find out what the max CPU is it can handle. See if a local computer shop has any used parts or if you have a flea market in your area, you might wanna look there. good luck and appy computering!
Mar 30, 2009 | Dell 2.8 GHz Second Processor for...
Processor
Pentium M 2.0 ghz if you update the bios. You would need Dell 600 Bios & that should be available on the Dell website under the support section. Hope this helps & please remember to rate my answer. Thanks.
Jan 25, 2009 | Dell Latitude D600 Notebook
I need a bigger cpu
The largest pentium 4 processor on the market is the 3.4 ghz pentium 4 processor it comes in extreme edition but thats rather pricey. Your motherboard should be able to support it. Your computer will probably support up to 4 gigs of ram.
Dec 14, 2008 | Computers & Internet
I have an eMachine T2240 with an Intel Celeron processor 2.20 GHz & 384 MB of RAM.  The only real complaint I have is that this machine runs slow - it is rather aged - and I tend to bump up against my...
Memory: Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot. You may purchase here.
This will give you the biggest speed increase.
CPU: I could not find specs for which cpus this motherboard supports. However, I had one of these same machines and succesffuly swapped out the celeron processor for a pentium 4 processor, 2.53 GHz. You should be safe finding a used processor on ebay that's a Pentium 4 2.2 GHz and it should work for you.
Thanks and please take a moment to rate as fixya.
Dec 12, 2008 | E-Machines T2240 PC Desktop
Processor and Disk space
The biggest processor available for the T20 is 1ghz. Be sure when replacing the processor that you get an IBM 133mhz processor. The memory is 1g max, the machine will hold two 512mb chips, and be sure that it's PC133 memory. You can put up to a 120g hard drive in the machine, be sure the hard drive is an IDE 4200rpm drive. These are the specs for the T20, and the maximum size this machine will hold. You can go to this max or anyplace in between.
Aug 27, 2008 | IBM ThinkPad T20 2647 Notebook
ACER E661GXM motherboard specs
Intel® Pentium® 4 processor, up to 3.2GHz, 400/533MHz system bus or
Intel® Celeron® processor up to 3.06GHz, 400/533MHz system bus
Above is a list of possible processors you can use on your motherboard.
Apr 10, 2008 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Intel D845GLLY Motherboard Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
