Question about Samsung SyncMaster 710VT TFT LCD Monitor
I have a Samsung AV-R720, when I start up the surround sound system I hear static coming from the right channel. The static seems to go away after time. Whats up
  • 2 more comments
  • jbrown6132 Apr 28, 2010
    Thanks for responding. You said that I should spray the switch, what switch???
    I have a Samsung AV-R720 Receiver. When I turn on the system, the right channel crackles for 10-20 seconds, then slowly goes away. What is the problem, what board do I replace to get rid of problems??? Where do I get the board and how much will it cost??
    No, none of these points are an issue, I switch speaker, or wires it isolates to the right channel. When I went on line and went to a Samsung web site, this issue is not uncommon. They stated that its usually in the unit, and that the board was the issue. That why I asked which board and how much, and where do I get it!!! Thats why I was specific on the Brand and model.
    Where can I get the part to replace, and how much do you think it will cost???
  • 286 Answers
This has nothing to do with shielding or noisy controls or bad cables.
The problem is caused by the PULSUS PS9829B digital audio processor. We ordered it in from a Samsung authorized service centre.
Problem is now solved. Unit works perfectly. If you have never tried working with surface-mount ICs I would skip it if I were you. This IC has over 100 pins on it. However the part is available from Samsung. Print this comment and take it to your local service centre along with your receiver. They should be able to repair the board unless they are wussies and cannot do surface-mount work.
Posted on Oct 21, 2010
Where do we find the part and i have the same unit but the static popping noise is all the time will the pulses be the problem
Posted on Apr 16, 2012
  • Samsung Master
  • 4,924 Answers
Almost all static noise is an issue of shielding ...so ..check (change ) the cable ...or the coupling (jack or whatever plug it has) ..check to be inserted right ..and move it a little and see if it has a position in which it makes the noise...if it does than the plug is to blame and it can be changed...probably the noise disappears when slightly moved or something like that ...This is applied to the cable too ...see if it is nearby any electrical device ...and check if the actual noise is heard when that device is on ....Any electrical device has an electr-magnetic field that (in case the shielding of the cable is not right or damaged in some place) will interfere with the steaming on the cable..
so ...to check if it is the cable ...just change them between themselves and see if teh static is still present ...if is not..get another cable...
also check the thing with the device ...you may have a TV or something like that and the cable passes near by ...and when this one is on to make the noise..
Posted on Apr 28, 2010
  • 1 more comment
  • Catalin Turcu
    Catalin Turcu Apr 28, 2010
    sorry it was just a misunderstanding...I was under the impression that it is an issue of a background noise...in this case it is the chanel amplification circuit...all systems these days have an amplification integrated circuit for each chanel apart ...and this is to blame ...its easy to locate them in the main unit ..cause there are as many as speakers..(channels for pared speakers)..and all you have to do is locate it and replace...if you have the actual diagram its easier..if not ..it is a chance that to be named..or to locate it by tracing from the output on the board...or just measure it ..to see which one is dead..
  • Catalin Turcu
    hmm if you locate the part ..it looks like a regular integrate about one inch long and (spider like ) half a cm wide...Im not sure about the serial ..but is written on it ..and here in Europe costs about 2 E (3 dollars)Im not sure there ..but the issue is the hand work ...if you do it yourself is fine...if you take it somewhere .it may cost about 30 or 40 bucks..but id it is only one chanel ...this is the only thing that can affect the volume..
  • Catalin Turcu
    you can get it on eny electronic parts store..or if you locate and copy the serial on it ..even on eBay..
    Brigadier General:
  • 3,513 Answers
Thanks for writing to Fixya.com.
Indeed, the gain switches in the MK I and MK I+ when brand new can cause the static you are experiencing. If you use come electronics cleaner and spray it into the switch and then move it to the various positions several times, it should resolve the issue.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on Apr 27, 2010
My Samsung AV-R720 receiver has Cracking sound in front right speaker when turn on. Cracking sound last 300 seconds and stop. But after I turn it off 10 mins to turn it on and cracking comes again.
Hi try spraying the volume control pot with. Electronic cleaner solvent u will have to open the receiver to spray the pot ....u can buy the spray on E,/BAY ......GOOD LUCK
Jun 11, 2016 | Samsung Av-r720 7.1 Av Hdmi Dtv Receiver
What is the Panorama, c-width and the dimension effects on my receiver?
copied from av-r720 pdf manual:
C-WIDTH : This sets the width of the centre image. The higher the setting, the less sound comes from the centre speaker.
• DIMENSION : Incrementally adjusts the sound field (DSP)from the front or surround.
• PANORAMA : This mode extends the front stereo image to include the surround speakers for an exciting "wraparound" effect with side wall imaging.
Dec 30, 2009 | Samsung Televison & Video
My Samsung HT-AS720ST (AV-R720) surround sound receiver started making crackling noises in the front right speaker. I've changed the speaker and cable, but still the same results. Is there any hope for...
Problem is now solved. Unit works perfectly. If you have never tried working with surface-mount ICs I would skip it if I were you. This IC has over 100 pins on it. However the part is available from Samsung. Print this comment and take it to your locat service centre along with your receiver. They should be able to repair the board unless they are wussies and cannot do surface-mount work.
Dec 05, 2009 | Samsung HT-AS720ST Theater System
Samsung AV-R270
is there a software update for a samsung AV-R720?
Sep 28, 2009 | GPX HTD2204 System
Samsung AV-R720 - front right speaker crackles
THIS RECEIVER IS JUNK. I had the same problem with my receiver and Samsung gave me a new unit as it was under warranty. 8 months later the replacement which was brand new did the same thing. Samsung tells me it is my problem now. I should have demanded another unit. the best advice I have is not to buy this product. Samsung won't help you when it breaks and it will break. Nobody seems to know how to fix it.......
Sep 17, 2009 | GPX HTD2204 System
Can't get all speakers to turn on in AV-1 function
can't seem to get the sound to come on. i knowe i have sound but will not turn on
Feb 09, 2007 | Amphion Mediaworks T-365 System
Computers & Internet Logo
1,127 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
