Question about Samsung SL502 Digital Camera
Cannot get pictures to import from camera to computer
When I hook up my camera to the computer the import screen does
not appear. I use other cameras (Kodak Easy Share) and it imports immediately. I took this Samsung to another computer and it imported
Is there something my computer needs for this camera to import
    Brigadier General:
  • 11,967 Answers
Blame Microsoft updates. Now, get yourself a card reader and end all your download problems.
Posted on Apr 25, 2010
Need to know how 2 download pictures from x1250 sanyo camera 2 pc
You need to connect the camera with a USB cable to the computer.
Only then the USB connection screen appears on the camera's monitor. There you select computer and press the set button.
The screen to select the connection mode appears
Select "Card Reader" and press the select button.
Now the camera is connected in the card reader mode.
If the windows automatic playback screen appears on the computer monitor, close it.
Double click on the desktop [Mediaimpression 2] icon to launch Mediaimpression 2.
The Mediaimpression 2 home page appears
Click the right top icon [Import]
Then the files in the camera appear on the screen.
From there you can chose the files you want to safe on your computer. You can chose or make folders where you want the files on your computer.
You can read this in the manual click the link
http://www.central-manuals.com/instructions_manual_user_guide_camera/sanyo.php
Oct 28, 2013 | Sanyo Cameras
FINEPIX a340 to windows 7
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Jan 27, 2013 | Fuji FinePix A340 Digital Camera
Import window in windows 7 does not appear to import pictures from camera
Consider NOT connecting your camera to your computer.
Aug 23, 2012 | Samsung SL600 Digital Camera
Read error appears after downloading pictures and looking back in the camera, some pictures have read error
When you hook your camera to your computer you are accessing it like a disk and changes made to "files" are saved to the disk. A common change is to rotate the image so it views correctly on the computer screen for images you turned the camera to take a portrait oriantation shot. That change is saved to the image on disk, then the camera can no longer display it because it is not the right "dimensions" for the camera (it is rotated)
Dec 13, 2011 | FUJIFILM FinePix S2950 / S2990 Digital...
I Can't see the pictures or even copy it when I connect it to the computer? what will I do? thanks. GODBLESSU!!!!!!!!
The solution depends upon the Operating System. There are many options for transferring the images from the Camera to the Computer. You can either use the supplied Software for transferring the images to the Computer or with the help of Windows Explorer.
Let's try to set the Camera in PTP/MTP Mode and check if it the computer detects the Camera as a Removable Drive. To set the PTP/MTP Mode, select the USB Connect option from the Main Settings 2 Menu of the Camera.
If the Camera is detected as a Removable Drive in the Computer window, then open the DCIM Folder to copy all the images.
If the Software is installed in the Computer, then the Import Media Files screen of the Picture Motion Browser appears automatically.
Click on Import option to import the images. By default, images are imported into a folder created in Pictures folder that is named with the date of importing.
This should help you in transferring the images.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
I need to know how to get my pictures on to my computer from my camera. do i need a disk. my computer don't have a hole for the chip. i do have the wire to connect to the computer. how do i go about...
To import pictures and videos from a digital camera
  1. Connect the camera to your computer by using the camera's USB cable.
    samshameem_2.jpgConnecting a camera to a computer with a USB cable
  2. Turn on the camera.
  3. In the AutoPlay dialog box that appears, click Import pictures and videos using Windows.
  4. (Optional) To tag the pictures, type a tag name in the Tag these pictures (optional) box.
    By default, the folder name includes the date the pictures and videos are imported and the tag name.
  5. Click Import.
    A new window opens and shows the imported pictures and videos.
Jan 08, 2011 | Computers & Internet
When I hook my camera to a usb port on my HP 763 running windows xp, the nikon screen appears & shows the s4000 in the display & 93 pictures to be transfered to my C drive. When I hit start...
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 02, 2010 | Nikon Coolpix S4000 Digital Camera
I HAVE A SONY DIGI CAM MODEL DSC W-5. MY PC IS NOW UPGRADED WITH WINDOWS VISTA AND SINCE THEN IT IS NOT POSSIBLE TO DOWNLOAD THE PICTURE TO PC. THE INSTALLATION CD ISSUED WITH CAMERA DOES NOT COMPITABLE...
  1. Turn on the camera.
  2. Insert the recording media containing the pictures into the camera.
  3. Depending on your camera, set the USB Connection or Transfer mode setting in the menu to the Mass Storage , Normal , or PTP .
  4. Use the USB cable supplied with the camera to connect the camera to the computer. IMPORTANT:
    • Connection through a USB hub or other USB device -- such as a printer or keyboard -- is not supported and cannot be guaranteed. Connect the camera directly to a USB port on the computer.
    • If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat steps 4 and 5 using a different USB Connection or Transfer mode setting. If the connection is still not recognized, further troubleshooting is available.
    NOTES:
    • The computer will automatically install the USB driver for the camera.
    • When the camera connection is established, an AutoPlay window will appear.
  5. In the AutoPlay window, click Import pictures .
  6. In the Importing Pictures and Videos window, click the Import button. NOTE: After the pictures have been imported, the Windows Photo Gallery window will appear and display thumbnails of the imported images.
If this doesn't work there is an updated driver available
Here
(from Sony Website)
Mar 19, 2009 | Sony Cameras
I have installed the Fujifilm finepix Z10fd software onto my computer. However, when I plug the camera into the computer the pictures do not load onto the computer. How do I resolve this?
is there a import menu in software to open first to import? try to uninstall software and hook camera up generic to usb and power on camera in playback and see if you can import into my pictures first-then import them into fuji program after reinstalling
May 16, 2008 | Fuji Cameras
Samsung SL502 Digital Camera Logo
175 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
