Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Wont agitate or spin
Fills and drains great, but won't agitate or spin
  • sully894 Jul 26, 2008
    I have a GE super capacity top loader. (6 months old) It was always going out of balance even though I'd load it evenly. Then it was like the inside drum was rubbing against the outer one. I took it apart - didn't see anything wrong - put it back together and now it won't agitate or spin. The motor sounds fine, the belt is tight, no oil on the floor. It fills and goes thru the cycles and then drains fine. Not sure what to do next. I probably voided the warrenty by taking it apart. oops.
    President:
  • Whirlpool Master
  • 2,651 Answers
Lift the lid up and down a few times , just before it closes you should hear it "click", if not its not recongnizing the door being closed ,
check the left hand hinge assy make sure the screw s on the side are real tight , play in th ehinge might be an issue
Posted on Mar 23, 2008
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
Greg20
  • 149 Answers
SOURCE: Fills, does not agitate, drains, spins, fills,
grab the agitator at the base and give it a quick push upward..remove and see if the white dome with bolt holding it down is stripped on the inside where it splines onto the transmission shaft. :)
Posted on Jun 13, 2009
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
  • 1028 Answers
SOURCE: washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Posted on Sep 13, 2008
huuum
  • 750 Answers
SOURCE: -no agitation
Hello
Welcome to Fixya
My name is Huum,
All functions operate normally except the machine will not agitate
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Dec 16, 2008
Noisy and wont agitate during wash cycle. will spin and drain.
the strap (belt) is chipped, damaged, the spindle from the VAT ruptured, cracked the tank squealing stops, etc. more details please
Feb 16, 2015 | KitchenAid Washing Machines
Replaced the clutch and motor coupler a month ago. Ran great. Washed tennis shoes. Came in to remove clothes, didn't spin. Wont agitate or spin, i could hear the motor running. Just replaced the motor...
Check for a failed capacitor under the control panel It is a start/run capacitor that the motor needs to start running. The motor will hum and if left will eventually burn out.
Aug 17, 2013 | Kenmore 23822 Top Load Washer
Gf1001l0ww fills spins and drains won't agitate
Check the drive to the drum and check the paddle.
It is possible also that there is no output to the motor for the wash cycle and if so the control panel board is a suspect.
Jan 25, 2013 | Washing Machines
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
Feb 08, 2011 | Frigidaire FWS1339A Top Load Washer
Kenmor top load Washer, Wshr fills, agitates, wont spin or drain
The Lid switch is the most common problem with what you have descibed.
some of the lid switches are located in the control area and some are on the right side center lid area and their is a hole where the lid has a plastic pin that presses it.
Jan 12, 2010 | Washing Machines
Agitator doesn't agitate. Fills, spins and drains
Unfortunately, that sounds like a transmission issue. Power is getting to the trans, or it wouldn't spin, but the other part of the trans that causes agitation is broken.
Nov 15, 2009 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
57 people viewed this question
Dan Webster
Dan Webster
prem mathew
