Question about Maytag SAV4655A Top Load Washer
My washer only pumps water out for 5 sec and shuts off. cant get it to start up again for 8 min.what wrong?
  • Maytag Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
WHirlpool wtw6600
HI,
Unplug your washer and open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass through it should not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there should be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidaire top load washer that keeps shutting off
i canty be 100 percent sure
without the model
but it sounds like you motor is trying to start but for whatever reason is cutting out on the overload. Meaning it gets hot,,,and shutsd it self off to save it self
ther ecould be alot of reasons for this,,, far to many to type here,,,
with frigidaire it could be a bad motor capacitor, or a bad start winding on the motor.......
or a simple as a sock between the tubs preventing the tub from truning
sorry i cant be more help
but figured you should have some sort of answer to at least5 investigate
Oct 28, 2009 | Washing Machines
MY GX 240 starts fine runs great any where from 30
Can your gas tank breathe? Is your fuel filter clogged? Might there be something in the tank that would obstruct the flow of fuel?
Check the tank by loosening the top to allow air to enter.
Let me know what happens
a
Sep 23, 2009 | Honda 8 HP Engine
Pressure Washer Pump and Engine Stops Suddenly
The pump might be binding against the motor, causing the pump to overheat and temporarilly "seize up" and shut the engine off.
After cooling down for a brief period (5~10 mins) the engine can usually be re-started, but the overheating problem will keep coming back.
This happens when the pump either wasn't seated against the engine properly during it's initial instalation, or the pump housing wasn't machined properly and the PTO shaft is trying to drive the pump at a slight angle = excessive friction = overheating.
Try this:
1) Loosen the bolts that mount the pump to the engine just enough so that the pump can be wiggled slightly.
2) With the engine power switch in the "OFF" position, slowly pull the recoil starter rope so that the engine / pump completes about two revolutions. This helps to align the pump surface with the engine.
3) Lightly snug the pump mounting bolts in a criss-cross pattern, then slowly pull the recoil starter rope again to ensure that the pump isn't binding.
4) Finish tightening the pump mounting bolts in the criss-cross pattern (approx. 21 foot pounds torque).
The entire process should take you roughly about 10 mins from start to finish.
If this doesn't remedy your problem, then try running the engine for 20 mins with the pump COMPLETELY removed so as to isolate the components.
May 04, 2009 | Northstar Pressure Washer 3000 PSI
Indesit wm12x wont finish cycle just clix through dial,can u help me ?
i suspect that you may not be draining water,if you watch the light flash it will flash at 1 sec interviles it will then stop for approx 3 secs and then start flashing again at 1 sec int,if you wait for it to stop for aprox 3 secs.when it start flashing again count how many flashes til it stops again for the 3 sec,thats is your fault code,if it is 10 or 5,then its will be your pump blocked or inop.
Apr 05, 2009 | Indesit W 123 Front Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Maytag SAV4655A Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
