Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
My whirlpool refrigerator is leaking.....I have a freezer on top frig and it is leaking on the inside.....any help would be great
    Sergeant:
  • 239 Answers
You have drain plugged, remove freezer back panel you will see ice under coils use hair dryer too melt ice and find drain hole keep heating hole until the water drains
Posted on Apr 25, 2010
  • Whirlpool Master
  • 8,220 Answers
Yep
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 03, 2010
Water leaking from the freezer into the frig through the vent in top of frig Model#ETIPHKXPQ00
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 21, 2011 | Whirlpool Refrigerators
Water is leaking out the bottom of the unit. It has a water dispenser inside the frig
Hi
There are various reasons as to why your refrigerator is leaking.Please check this bellow link to troubleshoot your issue:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itleaks
http://www.ehow.com/info_7972651_refrigerator-leak-out-bottom.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 03, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Frig cools works great all day then trips the gfci
Hi Sturkle;
Does this happen say- every 6-8hrs? If so you may find the defrost element has a short, or defrost timer is faulty. Defrost element is located in the freezer compartment, Time located an back of fridge.. Use a qualified person when playing with electrics...Cheers
Mar 29, 2010 | Whirlpool ET8GHMXLQ / ET8GHMXLT Top...
Water is leaking from top part of freezer down to bottom of inside of the frig. Frost is on the top of the frig in the frigerator.
FIRST STEP: UNPLUG THE REFRIGERATOR. AFTER IT'S UNPLUGGED, DO THE FOLLOWING:
Remove the food from the freezer compartment and place inside the refrigerator temporarily.
Remove the bottom panel and back panel from inside the freezer compartment. You will probably notice that the bottom of the inside of the freezer is covered in ice. Use hot water (not boiling) from the tap and pour it on to the ice that is formed on the inside of the freezer compartment to melt the ice.
CAUTION: DO NOT USE A HEAT GUN TO MELT THE ICE AS IT WILL MELT THE INSIDE OF THE FREEZER COMPARTMENT. ALSO DO NOT CHOP AT THE ICE WITH A SHARP INSTRUMENT OF ANY KIND AS THIS WILL PUNCTURE AND DESTROY THE INSIDE OF THE FREEZER.
If you have a wet vac, you can remove the melted water using the wet vac. Or you can use a towel to mop up the excess water. You will still have to pour hot water onto the ice until all of the ice in the freezer is melted. Patience is key as it takes time to defrost all of this ice.
You will see a drain hole in the back of the freezer compartment that is still clogged with ice. You will need to continue to apply hot water until the ice has completely melted.
Note: When the ice in the drain breaks free, you will see all of the water disappear as it empties out.
In Whirlpool refrigerators, the water runs to a tray underneath the refrigerator. You will hear the water empty out into that tray. Then you will know that you have completely cleared the ice from the drain pipe in the freezer. To double-check this, take a small cup of warm water and dump it into the drain hole and you will see it visibly disappear and run into that tray underneath the refrigerator.
Replace the freezer panels back into the freezer compartment and plug it back in and return your freezer items back in to the freezer and you should be all set.
Oct 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
MTF1955DRW Refrigerator that is leaking water from top of frig. not freezer. Turned it off, defrosted it and was better but leaked again. Repair man out twice now to put new gasket on to seal leak. Any...
Call Whirlpool they own Maytag now,ask for a different service company and a senior Technician,you have an air leak somewhere changing the seal again won't help.
Aug 23, 2009 | Maytag Refrigerators
Whirlpool refrigerator leaks inside
HI, First thing you do is remove the floor panel of the freezer. Do you see ice?
If there is ice, remove the rear wall of the freezer as well and start removing the ice. There will be down inside the drain hole also. A hair dryer works great for this project.
Please do not use sharp object/tools.
Now that you have the ice out of the drain, There is an after market drain transfer heat strip kit you need to buy and add.
Please let me know if I can help you. I have the kit on my web site www.whirlpoolpartssurplus.com
Thanks
Vic
Jun 20, 2009 | Refrigerators
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Amana Refrigerator leaking in the inside
defrost drain channel is almost certainly blocked in freezer, to rectify turn of overnight leaving doors open, turn on the next day 12 hours later and it should then work ok.
Jun 04, 2007 | Kenmore 44103 Side by Side Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
768 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
