Question about RCA TruFlat 27F520T 27" TV
TV turns on & off
Please help us as well in Florida...We've had the 27" TV for only two and a half years and now the set is turning off and on.
My observations since this began a week ago is that the TV warms up for about an hour before turning itself off and on (nobody is touching the remote, no power outages or power-surges account for the number of times it turns itself off).
We don't leave the TV unplugged @ night and during the day when we're at work, but when it gets caught in the glitch, we've simply unplugged it until the next day, thinking it its caught in the "built-in relay" problem that Tech Support for Thomson/RCA told us might be the cause of the same problem in the HDTV sets.
One question - could this issue be related to things attached to the TV, like a Wii and DVD/VCR combo? Just a suggestion....
  • 6 more comments
  • Anonymous Mar 10, 2009
    My TV (same model) does the same thing! Haven't had it that long.
    Does anyone know if RCA has a recall on this unit since so many are having the same problem?
  • pday Mar 18, 2009
    I brought my TV to a technician. Had the same problem. They were not able to help me at all! Does anyone know how to solve this problem?
  • ecurb13 Mar 30, 2009
    I bought two of these TV's when I moved to Florida in 2006. After about a year, the first one started having this same problem. At the time, I just chalked it up to bad luck because the second one was operating just fine. Last week I just started having the same problem with the second TV. Now I have two TV's that don't work.
  • Anonymous Apr 12, 2009
    i have a 27F634T and only had it for less than a year and it does the same thing if i leave it unpluged for about 3 mounths it will work fine for about 3 days until it starts going off and on
  • Anonymous Apr 18, 2009
    I have the same problem; I brought it in Dec 2008 and in March it start turning on and off by itself.
  • Anonymous Apr 22, 2009
    I bought it at Walmart and it will cycle channels and turn itself on and off. It's only about five months old.
    Tv just shuts off by it's self, the tv is about 2 to 3 years old.
  • kimberlybarr May 11, 2010
    How much is it to repair the power supply?
    Scholar:
  • 135 Answers
Hi there!
Exterior equipment attached to a standard tv cannot cause the set to switch on/off by itself.
I think you may have a power supply fault or else loose solder connections on the board, hence the "warming up" intro before the fault shows itself.
My suggestion would be a service technician if you are not familiar with electronics or TV's. Regards, JUS004
Posted on Mar 24, 2008
SOURCE:
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
Describe your Sony FD Trinitron WEGA This started
I have the exact same problem. If you get anywhere (I can't) please contact me at [email protected]. If I figure it out, I'll get back to you.
Good Luck.
T
Sep 09, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
RCA TV 27 inch 9 years old
The eeprom is bad. It holds memory for the micro...it is the micro's ram card so to speak. OR, you have horizontal problems that RCA's are know to have. Google your sets model or chassis # and the words "dead set". You will get plenty of info to help you.Good luck!!
barneyluc
Oct 02, 2008 | Televison & Video
TV will not turn on
I am by no means an expert but i have the same type of TV and have a similiar problem, first I thought it might be a heat-induced effect so I vacuumed the interior but no joy--then I carefully inspected the main board and found two components that looked melted. So I would suggest you vaccum the interior and then inspect. But be careful as I found one capacitor on the board that still had a charge after 3 days of the set being turned off, you might want to verify things with a multimeter before poking around.
--Hank Rausch
Jun 15, 2008 | RCA TruFlat 27F520T 27" TV
TV Problem
about the 30 sec turn off its a bad power supply probably more than tv is worth to replace it
Apr 22, 2008 | Orion STV2763 27" TV
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
Changing the default channel
I believe you will have to have a tv tech. do this adj. , this is set in the factory service menu which he or she can access.
Nov 27, 2007 | Zenith H27E35DT 27" TV
Tv turns black and white
No, the tube is not bad. There are a couple of very small surface mount components mounted by the main microprocessor that could be causing what you are seeing. They are very small and quite hard to unsolder and replace without losing them. The set should be serviced by a qualified tech familiar with the new RCA chassis.
Aug 21, 2007 | RCA F27650 27" TV
RCA TruFlat  27F520T 27" TV Logo
384 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
