Question about Bosch Nexxt 500 Dryer
My Bosch Nexxt 500 Dryer takes way too long to dry!
Sometimes it takes three cycles of permanent press to dry one load. Has anyone else experienced this problem and is there a solution?
    Sergeant:
  • Bosch Expert
  • 211 Answers
Check your flex vent hose on back of dryer are go out side your home an locate where the vent come out of your home an see if the air flowing out of your vent, if not you need to pull the dry out take the hose off of the dry an clean the lint out ok, an send me the money you find in the vent ok
Posted on Apr 25, 2010
I have a Bosch Nexxt 500 front load washer that will not drain when it gets to the spin cycle. The drain pump is clear and free from obstructions as well as the lines are clear and manually filling up
Sounds as if the rinse hold button has been set by accident.check the switches top left.if they are correct, then next query would be logic board has a problem, sometimes fixed by hair drying the board in cases of damp lack of use washer.if machine completes most cycle then I suspect rinse hold button is on or open circuit.
May 12, 2014 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
What could be a cause of water leaks from Bosch Nexxt 500 gas dryer?
Since there is no water lines connected to a Bosch Nexxt WTMC 6500 gas dryer, the water leak has to be from excess water from the clothes you are trying to dry. Which is probably more the problem.
Does your washer leave an excessive amount of water in the clothes after the spin cycle?
Jun 04, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
MY BOSCH NEXXT 500 ELECTRIC DRYER IS RUNNING ON 20 MIN AIR DRY BUT WITH NO HEAT. SOMETIMES BY SLOWLY MOVING THE DIAL WILL ALLOW THE HEAT TO RUN FOR A FEW MINUTES. THEN LINT SENSOR GOES ON. HAVE CLEANED...
Did you check this FIXYA LINK below? Appears to have lot's of answers!
Also I WATCHED the YOUTUBE video I recommended and NOTICED his DRIVE BELT is WAY too loose! Methinks THAT is why his dryer has problems!
Be SURE your belt is not to aged because they can STRETCH and then TRIP the "RESET SWITCH" he's talking about. Note the way his PULLEY shakes so violently... AND the action of the belt itself...
20 Most Recent Bosch Nexxt 500 Dryer Questions Answers
Here is another Link!
Bosch Dryer Won Heat 3 min FIX
And yet another!
(DON'T waste your time with the FOUR oval Links to the right! )
Dec 22, 2017 | Bosch Nexxt WTMC 6300 Electric Dryer
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Bosch Nexxt 500 Series Front Loading Washer
The only way is to disonnect the device from the controller board.
Sep 12, 2009 | Bosch Classixx WVF 2402 Front Load...
Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
Oct 28, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
234 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
