Question about Jacuzzi Home
How do i install an jacuzzi that has no faucet its a bathroom jacuzzi has no place for faucet it just has a hole for drain handle
    Top Expert:
  • Jacuzzi Master
  • 13,652 Answers
Either mount on wall or need to drill holes through jacuzzi 99 % of tubs dont come with faucets
Posted on Apr 25, 2010
Do all single handle faucets have pop up hole
All bathroom faucets should have provision for pop-up drain.
Aug 25, 2014 | Plumbing
How to remove bathroom single handle faucet ?
  1. Shut off the water supply
  2. Disconnect the supply lines
  3. Remove mounting hardware from underneath
  4. Pull the disconnected faucet assembly up and out of the sink
Jul 17, 2014 | Moen 4621 Chateau 1 Handle Bathroom Faucet...
We just installed a new moen 4 inch centerset Lindley faucett with drain for our bathroom. The drain piece has 2 molded holes in it. We are experiencing leaks from this pipe. How are we supposed to fix...
Ok I asked for some more information, but let me give it a try to help you with what I have here.
The two holes are for water to drain out of the over flow of the sink. If you look at the sink on the front side you may have to feel but there is one hole or up to three little ones. They take off water when someone walks away with the faucet on and they it goes down the drain and not on the floor.
Now if the sink your putting this in is a steel sink that does not have an over flow it will leak and you need an other drain system that is made for a sink with no over flow.
Places like manufactored homes, boats, campers would be where you would find a sink that does not have a over flow. Now with the over flow out if the sink does is not about1 inch thick.
if not use try more putty
Sep 12, 2011 | Moen Bathroom Sink Faucet - 4-inch...
Hi I recently bought a CA84667CBN bathroom faucet but lost the manual. How do I connect the water stopper?
http://www.hometips.com/diy-how-to/bathroom-faucet-installation.html
These pictures are not very good and there are videos because it's kind of hard to explain but, I'll try. The drain stop rod that goes through the fixture and would hang in your vanity should have a piece that bolts to it with holes in it. you need to pick the hole to go over the shaft taht sticks out of the drain pipe, That controls the stopper, taht will close the stopper when pulled up and, will open stopper enough to let water drain. You use the "v" shaped piece with the 2 holes in it to attach the two together. You have to position the v piece over both sides of the plunger piece and then squeeze and put the whole thing over the shaft of the pluger actuator. If you type, "how to install a faucett" in your search window, you can pick a video on how to install a "bathroom faucett" that will give you pictures. It's really hard to try to explain.
Jun 12, 2011 | Moen Home
Drain handle comes out of the back of the faucet and hits the backsplash. Is it susposed to come out at an angle? Not covered in installation instructions.
Yes on this faucet the drain knob is susposed to come out at an angle. There is no way to stop it from coming out at angle.
Feb 12, 2011 | Danze D223121 Antioch? Single Hole...
How to remove the handles,moen,eva,two handles
the small hole underneath handle where you put your hand has a small set screw(alan wrench)-should be able to see hole,loosen and wiggle handle should pop off, spin off packing underneath and pop out stem make sure water is off - whole new stem is cheap
Jan 30, 2011 | Moen Bathroom Sink Faucet - 4-inch...
My moen bathroom sink handle came off. The srew into the handle comes up from the stem? how do I access the srew to reinstall handle? Thank-You
pop the cap off top of handle with steak knife, screw is underneath,unless yours is like the one pictured,then its an allan screw from the back.you had one when it was installed and,these can be really stuck
Jan 28, 2011 | Moen Bathroom Sink Faucet - 4-inch...
Need to change washer faucet
Probably what you need to do is change the cartridge. You will need a Moen cartridge puller to help with removal and reinstallation. You can get these and the cartridges at most hardware stores. Shut Off Water first, remove set screw that secures handle and carefully remove handle. You may have to tap lightly on rim of handle to free it. There is a retaining clip that holds cartridge in place, it will have a small round hole on top. Carefully remove clip using neddle nose pliers or perhaps ice pick inserted in hole to remove clip.Install puller as per instructions and tighten nut to remove cartridge. Install new cartridge andclip. put handle back on and install screw. I need to back up here and say that screw is normally located under moen insignia in middle of handle. Pry cover off with screw driver or knife blade to access screw. After you have cartridge, retaing clip and handle reinstalled turn water back on and check for leaks. Hope this helps. Thanks.
Nov 11, 2010 | Moen Bathroom Sink Faucet - Single Handle...
I have a black enamal cast iron jacuzzi kitchem sink with 4 holes for the faucet predrilled..the holes are 3" in dia. where can I find a faucet for this sink?
If you have a 3" hole I would definately say that is a special order faucet, But if 3" is a typo you can get what are called "cockhole covers" to cover the hole you're not using. What i usually do is, find a faucet that will use the 3 holes and install a soap dispenser, filtered water spigot, or a instant hot water spigot to fill the fourth hole.
If 3" is not a typo you might try to contact a granite countertop co. or call Jacuzzi and install a larger plate that will cover large holes and have new (smaller) holes drilled for a standard faucet
hope this helps
Jun 03, 2009 | Jacuzzi Kitchen Iron Black Finish...
Home Logo
153 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
