Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
, LE ' BLIKING AFTER 2MIN FROM START
A problem ,LE ' cod after approx. 2 min from start.
what can I do?
  • 523 Answers
Replace the pump and motor
Posted on Apr 25, 2010
How do I know how many minutes left while recording from analog?
you would have to use a stop watch,and time both processess start to finish and take notice of counter at the end, then this will give you an idea of each click of the counter example.
30min to rec, counter show 60 on it, 60/30=2min
1 on counter = 2 min.
Jan 31, 2016 | Audio Players & Recorders
Motor starts and runs for one min. then stops If you wait 2min it will start agin then stop after one min. Honda gc5hp
Sounds like a fuel delivery problem.
I'd be checking the fuel fulter, then draining and cleaning the carb.
Jul 03, 2015 | Cars & Trucks
Monitor shuts off after approx 2 min when i start. i turn monitor switch off and turn on again and stays on approx 2 min and shuts off again
Go to control panel > Power options and check the power settings there. Are the settings for "Turn off monitor" set to 2 minutes? Increase the time and see if there is any changes.
If the above does not solve it, it's quite likely that your monitor's power supply is giving problems. Turn it in for warranty/repair.
Mar 07, 2011 | HP 2009M Monitor
LE code flashing on WM1812CW
LE code is overload on motor. This unit actually has a magneto and stator. This is what needs to be replaced. Usually find a magnet cracked.
Aug 27, 2009 | LG WM-1832C Front Load Washer
Dryer gets hot and turns off timmer still going,wont restart for approx 20 min
there is a thermal switch it cuts out the heater element when its at temp. also so has a thermal switch that cut out the unit if it gets to hot. there will be two thermal switches or a combined one. it will have 2 to 3 wire on it and is directly connected to the the drum. one of these is the problem the thermal switch is working as its cutting out the unit. to stop a fire.
Jun 18, 2017 | Whirlpool GEW9878LW Electric Dryer
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
Estimated time 2minutes blinking with an "F" what does this mean?
Are you certain its not blinking F 02 I have a similar problem and the only way I can get it to finish is to hit pause and let it sit overnight befor hitting start again, I cleaned out all the huses and the pump filter which were a mess wet lint and change respectivly, This helped (now I get one load done before it stops)
Mar 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
99 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
