My dvd drive will not open. it says it is open on the television but it isn't. how can i get this to work since my husband has a disc in it?
    Genius:
  • 1,550 Answers
Quizas el disco no estaba puesto correctamente y al introducirlo trabo a la charola checa esto abriendo el aparato.
Posted on Mar 23, 2008
The player says it is open but it isn't and wont play a dvd...
Does it make a noise as if it is opening the drawer? If so the drive belt might need replacing. If you can get a rubber band the same size it will work for a while.
May 27, 2012 | Televison & Video
My dvd drive disappeared from computer/device manager. Drive opens, and spins disc, but isn't recognized by Windows 7.
Does BIOS still recognize the drive? Also, check to make sure the IDE / SATA cord is fully connected, the dirve will operate with power, but wont be recognized without the other cord. If the cords are connected and BIOS reads it then win7 should autodetect it. If its not, it may be the disc itself, try putting something you know for a fact works. If the problem persists, try adding the hardware through the device manager, or deleting all mention of it, then re-adding it through the device manager. This tricked worked for Xp machines, although Ive never had to try it on a Win7 machine, it should still work.
Jul 28, 2011 | Compaq Presario F767NR Notebook
My dvd writer\drive isn't reading any disc can any 1 try to tell me what should i do?????
Make sure you have an updated driver then restart your computer. If that doesn't work, comment back.
Jul 17, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
DVD player isn't working. A DVD can be inserted and ejected without any problems. WHen disc is inserted it continues to make a small wurring noise and continually displays "Loading". All...
Good day to you!!
Did you try to check if the disc have many scratch?please check it then replace it or try another kind of disc (original) if possible so we can find out where the problem is, in the disc or in the DVD itself..
for comments or question please feel free to click the " ADD A COMMENT " below
If this suggestion helps you please don't forget to rate or have a testimonial with me...
Thank you for using FixYa!!!
Jun 10, 2011 | Televison & Video
DVD drive has stopped reading discs, it attempts to read the disc and then goes to open tray??
This is a very common problem for the Xbox 360. Fortunately it usually isn't a serious problem. The first thing I would do is clean it. If you have a bottle of air duster, that would work well. Here's a link to a product you might want to try. http://www.amazon.com/ENDUST%C2%AE-Electronics-Non-Flammable-Bitterant-248050/dp/B002XIHQ90. You can also go to any major store to find it like Walmart, Staples, Office Max etc.
If that doesn't work, I would recommend a disc drive replacement. The lasers in the disc drive tend to go bad and don't read the disc normally. These are only around $30, so it is better than buying a new Xbox. If you feel confident, you can do it yourself or send it in to someone and they can do it. Good luck!
May 05, 2011 | Microsoft Xbox 360 Elite Console
Asking to format full disc
The simple trick is to put a disc into desktop DVD recorder. If Your DVD will be recognized, then copy all content to another DVD or camera. I've seen it before. Must work. Sincerely.
Sep 12, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Is using the DVD player on a lap top frequently a bad thing?
The life of the DVD drive depends on the quality of the lens and how it is used.If lots of local cds and dvds are used in that dvd drive then it really affects the life of the lens.Also dvds which has scratches and other deffects in the reading side will make the lens to strain more to read the content in the disc.If clean discs and branded discs are used in the drive its life will be long enough.I have a drive which is working for the past 10 years.So if the drive is properly cared then it will last till you think to replace your laptop
May 12, 2009 | Compaq (158165-001) DVD Drive
DVD stuck in sony blueray player bdp s300
Step1There are a few ways to get your dvd/cd drive release itself. The first thing you should try is shut your equipment completely off for a couple of minutes allowing it to cool down. Once you turn it back on try to press the release button on your equipment. Step2If that does not work try to use a very thin flat tip screwdriver. Insert in on one of the sides of the dvd/cd drive and try to pull it out softly while pressing the eject button simultaneously. Do not force it out but give enough pressure while pressing the eject button. Step3More than likely inserting a screwdrive should release the dvd/cd drive. You can also try a butterknife as well just don't use to much force. Something else to check for is to make sure the power is acutally on for the device. If you are trying to open a drive that is not even on it will never open up for you.
Apr 03, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Cannot get DVD recorder DVD 3470H to download from hard drive to a disc. The machine is about a year old and I'm using recordable DVD-R When I try to record onto the disc I get a screen which says the...
Hi Guys,
Thanks for the response.
I've solved the problem.
I was trying to download a programme that was too big from the hard drive to the disc.Once I inserted a divide in the progeamme everything worked Ok,
Cheers,
Dec 16, 2008 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
