Question about Vizio L32 32 in. LCD HDTV
No red! i moved my tv to the otherside of the room now i have no red! how can i fix it?
  • Vizio Master
  • 8,457 Answers
Recheck ur coalax input incomming signal.Tries other source of input incomming signal.If same thing,than some how ur Tuner board is dead.
Posted on Apr 25, 2010
I moved my LCD TV from one room to another now I can't get ABC channels. What do I do
sadly when we do not have any idea what kind of connection you had or have after moving rooms . makes it hard to guess on the FIX . what kind of antenna do you use /input
Jul 06, 2016 | Televison & Video
Just moved my tv (jo47baird) from 1 side of the room to the other now it wont switch on just the red standby light on it power botton dont seem to do anything.
my tv has done the exact same as yours has I have worked the problem down to 2 things it could b the LDVS board that you can buy for around £20-£25 or it could be or it could be the inverter and you can pick one of those up for £45-£60 hope that helps once I have fixed mine I could tell you what it is for certain
Dec 28, 2010 | Televison & Video
Hi I have 2 faulty LCD TV with A1T4l30PN00 power supply. One of the lcd you turn on the tv with remote control and the red light is bliking but will not turn on the TV. I know the power supply is faulty...
TV is often turned off when some parts of the circuits got too hot. You should try to use a room fan to cool the back of the TV and see if it improves by itself before you try to fix the TV. Overheating is often caused by condensation, which also can be dried by a room fan slowly move the air..
Nov 30, 2010 | Televison & Video
We had a power surge in our living room while the TV was on. It was also plugged into a surge protector, however, everything else turned back on but the TV. There is no power going into it at all, as if...
Sounds like it might have blew a fuse on the AC input to the power supply, have to remove the back and look for a fuse near where the AC wires go from the plug on the tv. If the fuse is good
the power supply board will have to be checked or replaced..Next time consider buying a surge
protector that starts clamping at a lower voltage. Panamax brands usually start going to work
at 150v rms, where most others start at 330v rms..
Oct 21, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Green tint to picture.
Are you using the componant connection on your tv? If so, check the red, blue and green cable connections on both ends. They carry your
picture info to the tv. The audio is carried by a red and white cable. There should be 5 cables for a componant connection. 2 reds, 1 white, 1 blue and 1 green. I hope I have guessed your problem correctly and this helps you.
Apr 07, 2010 | Sansui HDLCD-1900 19 in. LCD Television
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
X360 AC Adapter stays orange
try to unplug and plug in a few time otherwis cant help ya never had that problem
Apr 14, 2009 | Microsoft Xbox 360 Arcade
Red line running down one side of my Zenith 50 in (Z50pg10 model)
its the problem of loose soldering joints of some components.due to which you r getting this problem.as the reparing cost of this problem will be negligible but the tv unit has to be opened to solder the main board.but the unit will loose its warranty because it is opened.so you just send it back and get it replaced its the product defect in your tv.it will get replaced.
Jan 29, 2009 | Televison & Video
How to connect headphones if the tv doesn't have a headphone jack
Hi!
You can buy a rca to 3.5mm jack adapter from the link---
http://www.amazon.com/gp/offer-listing/B0002KR5Q0/ref=dp_olp_2
And it will help you to use a headphone with your TV.
Thanks
Rylee
Jan 23, 2009 | Daewoo DLP3212 32 in. LCD Television
Interference?
The picture tube on a TV can be magnitized by the Earth's magnetic field. The noise heard when you turn a TV on (usually followed by a static noise on the face on the TV) is called degauss. What this does it remove any magnetic variations on the tube due to things like the magnetic field and speakers. However, changes to the TV in orientation to the Earths magnetic field will cause the tube to have a magnetic bias. This is most prominent when turned 90 degrees. The easy way to clear this is to turn the TV off for a little while and then turn it back on. But remember that any movement once it is on can cause the discolorations to reappear. My suggestion would be to turn the tv after you've moved it to the location you'd like to view it.
Nov 15, 2007 | JVC AV-36D502 36" TV
Vizio L32 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
