Question about Whirlpool Calypso GVW9959K Top Load Washer
Help My washer is only one year old and when u turn it on it runs for a second than it shuts off. If you mess with it u will get a LS code but it does not flash that. and when it runs for that second u can hear a click noise than it shuts off
  • 4 Answers
Not a complete answer, but this might help. The manual says this is a lid switch error. You can find the manual at: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Hopefully this is an easy, inexpensive fix. Good Luck!
Posted on Mar 23, 2008
Started a load of clothes turn on the washer and it overflowed wiyh water making a huge mess. the washer is about 10 years old. What's wrong?
If the water will not shut off when the machine is stopped you need to replace the valve assembly. It is an easy job, as the assembly is accessed from the rear.
If the water will shut off, then the problem is in your pressure system or timer. Check the air tube, and if that is ok, your problem is likely the water level pressure switch.
Jul 14, 2011 | Maytag Washing Machines
Washer doesn't stay running. filled with water, then shut down then filled some more and now stuck doing nothing. If push start button if runs for about 5 seconds then shuts off. 10 years old.
For being 10 years old...I'd say R.I.P Neptune. A 10-year-old dryer is going to cost you more in repairs than the cost of a new machine! And even if it is cheap enough to fix, the parts may be no longer available. I used to work at the Harrisburg PA Sears Parts/Service Center...trust me...I know.
Jan 29, 2010 | Maytag Neptune MAH6500A Front Load Washer
My Kenmore Elite Oasis He Washer model #110.2706 will not fill with water. I have checked for blockage in the water lines and they are clean and clear. The washer is only two years old. It will hum like it...
Your fill valve needs replacing. Not too expensive to change. This is all based on the fact that you have checked both feeds to the washer hook up and that the shut off lever is fully open.
Jul 29, 2009 | Washing Machines
Unit is not cooling
call factory service if only 2 mos old. has 1 year on it. if you mess with it it will ruin your warranty.
Jun 08, 2009 | Whirlpool Refrigerators
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
F 70 code on the Kenmore elete smartheat HE4
hello Whgispers42,
Huuum At your service!
You said,
We frequently have to start the dryer several times during one load. The dryer will run fine for a while then all the sudden give 3 beeps and then the F 70 code. Sometimes when you go to start the dryer you can press power and the panel will light up for about 3 - 5 seconds and then shut off again, this will happen several times in a row. We have been unable to solve this issue ourselves and are becoming very frustrated since this washer/dryer set are less than a year old. Any help you could offer would be greatly appreciated. (If we are unable to fix this problem soon, it is likely that the dryer will make a sudden leap from the second floor window to the backyard)
Try this first!!
This is an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
If this does not help, you said the machine is not one year old.
All appliances have a 1 -year warranty and the service and parts are free for that first year!
I hope you succeed with my recommendations.
Please contact me with your progress1
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Jul 27, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Calypso GVW9959K Top Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
