Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Tub will not turn
When turning washer on it makes a humming sound
    Habit-Forming:
  • 143 Answers
Is the water on to the washer,if water on may your fill screen are clog up with dirt.are you good have a bad motor
Posted on Apr 24, 2010
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
THIS WASHER WILL NOT COME ON, IT ONLY HUMS
Could be items between the tub. Or item in the pump.
Sep 09, 2012 | Danby Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Motor is humming loudly.
Motors hum, and your right, it could be no worse than normal.
I would be suspect that there is a gear stripped in the gearcase, since this is a direct drive washing machine.
Reassemble the motor back onto the washer. Run it through a cycle manually (rotate the timer by hand) until the motor turns, then look to see if it's turning. If it is, or even more so, if it pumps water out of the tub, then it is probably the stripped out gearcase.
Reply with you findings and more advice.
Jan 23, 2009 | Kenmore 24872 Top Load Washer
Kenmore washer 90 series Washer will not spin
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Washer wont run but is trying to
Sounds like the motor or capacitor (next to the motor), the capacitor helps the motor to start, once running a switch inside the motor disconnects the capacitor from circuit.
Mar 18, 2008 | Maytag PAV2300 Top Load Washer
My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
Jun 02, 2006 | GE WSM2700D Top Load Stacked Washer /...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
