Question about Brother Multi-Function Center MFC-3360c All-In-One InkJet Printer
It showing me near empty cyan what does it mean
  • 4 Answers
It's time to change your cyan ink cartridge.
Posted on Apr 25, 2010
No Cartridges. Open Scanner cover, then reinstall ink cartridge. All Cartridges are full
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty.
To make sure about the real issue unplug the mach from the power outlet then plug it back in after 10 seconds.
If the display show: "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace. If the display shows "ink empty Y" it means that yellow needs to be replace.
Even if it looks like the cartridge is full, it really needs to be replace so that the machine will work again.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
I just changed my yellow ink and printer is still saying no cartilage need to replace
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty. Try to unplug the mach from the power outlet then plug it back in after 10 seconds. If the display show "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace.
May 03, 2011 | Brother MFC 240C All-In-One InkJet Printer
What do i do when my printer said near empty cyan
It just means it will soon need to be replaced. Be ready with a new Cyan cartridge (blue).
Apr 15, 2010 | Brother MFC-5440CN All-In-One InkJet...
What does cyan mean on a brother 240-c all in 1 printer it says replace cyan it wont do nothing
Cyan is the "blue/green" ink cartridge which is required to print in full color. Some printers stop working when one or more ink cartridges is empty. Get a complete set for some savings and for the next cartridge that gets empty. Printers are cheap now, it's the ink that gets costly.
Mar 01, 2010 | Brother Multi-Function Center MFC-240C...
Cyan Cartridge not working
Show empty or not recognized (cross sign)? Check connector at chip and at head carriage. Do replacement procedure form status monitor (how to..). Do replacement ink tank one by one with cyan ink first.
Jul 25, 2009 | Epson Stylus RX425 Multifunction...
Error 41 near empty black and near empty cyan.
first, the error 41 will eventually come back sooner if not later.
error 41 means that your printhead is failing.
the error that its giving you now is that your black and cyan cartridges are empty. there are 4 colors in your prnter.
May 31, 2009 | Brother MFC 3220C All-In-One InkJet...
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
My ink shows near empty and they are not
The catridge tank is full, still got message NEAR EMPTY CYAN. Pls advise. Thanks
Jul 13, 2008 | Brother Office Equipment & Supplies
Screen reads "Near empty Cyan" but I just replaced the Cyan ink cartridge, its full.
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until all startup noises have stopped. Open lid and reinstall cartridge. This will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the power off and pull all the cartridges out. Look a the side of the cartridge, you should see a window with a little plastic tab sticking out. This tab should be blocked by a black float inside the cartridge. If you cannot see the float, and the tab is clear with no ink in it and no float tab blocking it, it means the cartridge is empty even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the noises have stopped, open the lid and install the cartridges. If you're still getting an error saying either a cartridge is not installed or is empty, then one of your cartridges is empty. Redo the previous paragraph.
Oct 05, 2006 | Brother MFC-5440CN All-In-One InkJet...
Brother Multi-Function Center  MFC-3360c All-In-One InkJet Printer Logo
416 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
