Question about Garden
My block wall got wet because of a neighbors drainage problem. the drainage problem is fixed but the face of the block is a little crumbled, loose etc. if I wire brush it the loose stuff falls off. I want to repaint it but think something else should be painted on first with more body to it than paint. What should I do
  • hsplv Apr 25, 2010
    the wall has been dry for at least 30 days. this a is concrete block wall outside between my yard and the neighbors. thanks
    thanks I knew there was something I should do. I just was not sure what. Thanks again.
  • 776 Answers
When was the draingae problem fixed,?
I mean how many days have gone by since the block wall has been wet?
How wet is the wall plaster?
Waiting for a response.
Posted on Apr 25, 2010
  • Dushyant Bist
    Dushyant Bist Apr 25, 2010
    OK, there would be some repair work that needs to be done first.
    Use the wire brush to take out the loose stuff(Reason: If you do not take out the loose stuff first, any paint that you put on will not stay for long as it come off).
    After taking out the loose stuff, fill the empty area with some POP(Plaster of paris), found easily, dries easily abd is durable.
    Once that is fixed you can paint it the way you want.
What are the best type of fixings for securing something fairly heavy to a breezeblock wall?
Hi, I've used these fixings for TV's up to 35Kg on wall mounts, no problems so far, just pick carefully the range is large:
http://www.rawlplug.co.uk/products/mechanical-anchors/sleeve-anchors/r-rlk-rawlok
Nov 29, 2015 | Televison & Video
How do I find the drain pan for the air conditioner in my 2003 mitsubishi spyder eclipse
Sounds like you have a blocked drain hose that drains the water that runs down your windshield when it rains or you get a carwash. Look under the car right in-line with the bottom of the windshield on the passenger side, you should see a little drainage hole. Stick a coat hanger up the tube to unblock the drainage tube.
Oct 11, 2014 | 2003 Mitsubishi Eclipse Spyder
Which way do you face a dehumidifier
Normally that will not matter too much unless you want to reduce the heat you accumulate in the work space with those. They do produce a lot of heat in the process of drying the air going into the compressor..
Sep 19, 2012 | Welding Tools
I have two (back to back separated by a wall) Kohler toilets. Model K3589-47. One is always loosing the water in the bowl. It leaks out slowly but always does it. When I flush the toilet on the opposite...
You will need to check the drainage fitting these toilets are draining into. If it is a cross tee fitting without a baffle you are getting throw over across the fitting and it will not stop. The only fix for this is to replace the fitting in your drainage system. In Illinois it is a code violation to put this type of fitting in that application.
When these power flush toilets come out it made this problem worse. In short there is no fix for this problem other than redoing the drainage system.
Feb 10, 2011 | Kohler Home
I have an extension in my house where the bricks are flaking and crumbling. its not rising damp as the bricks are very dry. the worst affected areas are just under the window sills. Please help Vladimir
Check all round the window and ensure a good seal with the brick and sill [use silicon sealant at the joint between the window frame and the brick & sill and brick] and that the sill has a drip bar [ridge or channel under the sill running sideways at the furthest away from the wall] If not put one on the underside. Almost anything will do [sounds silly but an elastic band will do temporary or even a line of the silicon] so long as it collects the drips from the sill. also ensure that the sill slopes downward & away from the wall
How old is the extension ?? I ask because if it is 50+ yrs you may have lime mortar which lets the bricks breath and if this has been re-pointed later with non- lime mortar [i.e. portland cement mortar] any water which gets in above will not escape out through the lime mortar below.
Secondly, if this is a north or east facing wall getting little sun and if the bricks were originally not good, frost & freezing will cause the flaking.
Bricks - has the wall been built with facings or commons. commons will spoil [flaking] sooner.
Do your bricks have a frog. That is a hollow in the middle [& looks a bit like a cake which has sunk in the middle] The frog should be facing down otherwise water will collect You can only check this by taking a brick out [applies mainly to modern bricks ]
Oct 22, 2009 | General Hand Tools
Water leaking in glove box? looks like there is a hose that comes into the box... water is dripping from that hose under the near the back of the engine .
There are three possible fluid can leak though the glove box.
Leaves and dirty block the drainage pathway..
Rain water/car wash water will seek the lowest spot.
AC condenser water drainage pathway may be block.
Windshield washer hose come off and window washer fluid somehow find it was to the interior.
Try to identify the smell of the liquid. It may just be Wet ones wipes.
Good luck
Jul 15, 2009 | 1998 Dodge Caravan
I keep getting error message F04 on my BOSCH exxcel 1400 express washing machine. What does this message mean and how can I fix it?
  1. Loose debris blockin pump - Clean drain pump on the bottom of the machine,
  2. Drainage pipe and or drainage hose blocked - I would like help on this as well.
Mar 01, 2009 | Bosch Washing Machines
A/C unit leaked out of front
pull out the unit and make sure the drainage is not clogged with slime and dirt. there is a drainage from the front to the rear. clean it before putting it back and tilt it a little bit towards the back too as you return i in place..
i hope i was able to fix your problem...
pls rate me..
tnx,
drcool
Jul 22, 2008 | Friedrich CP12C10 Wall/Window Air...
Water in filter ,pipe doesnt seemed blocked couldnt find anything undid it all
DEFINATELY A BLOCKAGE OR RESTRICTION ON THE DRAINAGE SIDE.DISCONNECT THE PIPING COMMING FROM THE DRUM TO THE DRAIN MOTOR. MAKE SURE ALL IS CLEAR. REMOVE PUMP AND OPEN PUMP HOUSING TO INSPECT.(BLADE COULD BE LOOSE ETC). FINALLY RUN WATER INTO DRAIN PIPE AND EXPELL WATER BY BLOWING HARD.IF BLOCKED, RECTIY. REASSEMBLE AND TRY AGAIN.
Jul 19, 2007 | Whirlpool AWM029 Front Load Washer
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
