Question about KitchenAid Dishwashers
Water inlet leak
How do you replace water inlet gasket on kitchenaid kudg25shbl1?
    President:
  • 949 Answers
Are you speaking of part 4 on this image? If so you need to rotate the Inlet Bezel part 5 counterclockwise and pull off,
Posted on Apr 25, 2010
KitchenAid Dishwasher Leaking
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jul 16, 2010 | KitchenAid KUDC25CH Dishwasher
My KitchenAid Superba (whisper quiet ultima) started to leak out the front when it is running. Is this an easy repair or should we think of replacing the dishwasher? BTW - we love this dishwasher!
Hello. If the unit is over ten years old, I advise against repair. But if you do wish to consider repair, here are the things to look at
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Mar 18, 2010 | KitchenAid Dishwashers
The dishwasher leaks.
Check the following in the same order as i mentioned :-
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | KitchenAid 24 in. KUDG25SH Built-in...
Leaks from handle
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Jan 27, 2009 | Danby DDW1805W Designer Series...
Washer is overfilling
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 25, 2009 | Whirlpool 24 in. GU1200XT Built-in...
In door water dispenser leaking on my kitchenaid superba
Hello , I can help , If water is coming out of the tube in the door the only problem you could have is the water inlet valve not sealing all the way causing water to seep out and leak, this is normal to happen over time and the only way to fix it without turning your water off to the unit is to replace the water inlet valve , it is not extremly difficult and will cost about 50 dollars. it is the part that you connect your water line to in the lower rear of the unit. This should get you going if you have any questions just ask. tell me how it works out.
Phil
Jan 07, 2009 | KitchenAid Superba Architect KSCS25INSS...
Brand new dishwasher installed and water leaks out bottom of door
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher leaks water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Nov 03, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Leaking water on floor in front of dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Leaking Dishwasher Help!
hi there,
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
Dec 12, 2006 | KitchenAid 24 in. KUDI02FRSS Stainless...
Dishwashers Logo
116 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
