Question about Kitchen Ranges
When I select to clean my oven a message appears that said (door). i MADE SURE THE DOOR WAS CLOSED GOOD BUT THE DOOR MESSAGE DID NOT GO OFF. ALSO YOU DO NOT HEAR THE DOOR LOCK.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Sounds like the unit no recognizing the door is closed, due to either a bad light/door switch or a defective latch assy, is the oven light going out when door is closed??? and depending on model do you have to manually lock the door?? (there would be a handle atop the door if so)
Posted on Mar 23, 2008
SOURCE:
Stove/oven whirlpool model GGE 350LWSOO serial DY3052134 How do I clean the oven????
The model is GGE350LWS00; the self-clean cycle selection is a bit different for this Whirlpool double oven range. Make sure that the oven isn't above 400F before starting the self-clean cycle. Close both oven doors. Press Precise Clean for the appropriate oven; only one oven can be cleaned at a time. For the upper oven, the button is next to the Toast button. The lower oven's Precise Clean is directly below the one for the upper oven. (If the oven doors are open, you will see Door. If the doors are not closed within thirty seconds, the Self-clean will be canceled.) Then press Presets (to the right of the zero button in the number pad) to select the type/ length of the cleaning cycle. You only need to press this once if the default Medium cleaning cycle is appropriate. Press Presets additional times if you need to cycle through to the Heavy or Light cleaning options. The cleaning cycle should start 4 seconds after you last press Presets. If the door locks do not properly engage, the self-clean cycle will be canceled. If the lock mechanism is broken or not getting the message from the control board, you may need check the lock, the wiring or control board to determine the source of the issue. See https://www.searspartsdirect.com/model-number/gge350lws00/1198/0124111.html .
The manual is available at Sears Parts Direct here: https://www.searspartsdirect.com/partsdirect/user-manuals/gge350lws00-whirlpool-parts-manual . The direct link to the manual is currently https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0909156.pdf . See page 17.
I hope this helps.
Jul 15, 2018 | Ovens
How do i turn on the self cleaning device.
make sure the oven door closes fully, nothing preventing it from closing. Some brands want you to remove the racks from the inside of the oven before it will activate the cleaning cycle. once door is completely closed, select the self clean cycle and press start. if you have a lock that you manually have to lock (older style of ovens), you will have to lock it before it will enter into the self cleaning mode. most of the time, if there is an issue before you try to enter the cleaning mode, it should tell you on the display,...i.e...remove racks, lock door, etc. good luck. look for me on 6ya if you need more detailed help.
Nov 23, 2015 | Kitchen Ranges
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
Self cleaning instructions
If the model number is correct, the self-cleaning instructions are as follows:
1. Make sure oven door is closed and press "CLEAN".
2. "REMOVE RACKS" should be displayed. Remove all oven racks to avoid damaging them.
3. Select "CONTINUE" using the Quickset pads on either side of the control panel.
4. Set LIGHT soil level by entering "200" using the number pads for 2 hours cleaning. Select MEDIUM for 3 hours. Select HEAVY for 4 hours.
5. "CLEAN", "TIME", "LOCKED" and the cleaning time countdown will be displayed while the oven is cleaning.
6. "OVEN COOLING" will appear when the cleaning time is complete, but the oven door will remain locked until it is safe to open. (approx. one hour after cleaning cycle ends).
These instructions are almost verbatim on page 23 of your owner/operator's manual. If you no longer have a manual, you can go to managemylife.com and enter your model number under the "Manuals" link. Your owner and installation manuals are listed in a .pdf (Adobe) format that you can download or print for FREE.
If you have any questions, or if your model number is different, please post back and let me know. I hope this helps you.
Feb 20, 2010 | Jenn-Air JES9860 Electric Kitchen Range
My oven door will not shut all the way. It
It is probably the self-cleaning latch that keeps the door from being opened during the self-cleaning cycle. Looks like it didn't retract all the way. Did you use the self-cleaning cycle? . Do this: Quiet the house down, open the door slightly and close it, letting it hit the obstruction. Do this again and again. You don't have to close it hard at all; in fact, do it gently. By listening, you will be able to hone in what is keeping it opened. Then go from there.
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
DCS wall oven door won't close
there is a broil stop integral to the hinges but shouldn't be the problem. make sure the little swinging stops used to remove the door assembly are rotated up and are in the "stowed" position.
Jan 09, 2009 | Hotpoint RB787 Electric Kitchen Range
GE Range Model GRCR3825ZWW-1 DOOR error code on range display
The door latched Micro-switch is not working or is dirty.
Remove the back panel, in the middle of the back there will be a metal arm that moves in and out when self cleaning latch is closed and opened. This arm pushes two or more Micro-Switches in the back, they are dirty or not working and need replacing.
Nov 05, 2008 | Kitchen Ranges
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Self clean inoperative
Dear Superglide, An error code "F5 E1" means "door latch not operating". In such situation I would recomend to replace the oven lock assy (part # 9782611 ) which is located on the back panel.If you are going to do it yourself - DO NOT forget to unplug the power cord first. About service manual - try to call Kitchen Aid directly.
Dec 13, 2006 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
89 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
