Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Light all three will not light - KitchenAid KHMS155LSS 1000 Watts Microwave Oven
  • KitchenAid Master
  • 9,047 Answers
You'll first want to unplug the oven, then remove and check the bulbs.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. If you still have trouble, let us know directly.
Posted on Apr 28, 2010
All three lights on my microwave ge model 1800 do not work. Is there a common fuse or something
suggest you go back to 10 amp globes and check that the fuse is good
Jan 01, 2015 | GE Microwave Ovens
How do I change light bulb
Lamp replacement requires removal of the outer cover to gain access. There can be dangerous voltage exposed inside even with power disconnected so extra caution is advised.
Sep 23, 2014 | Microwave Ovens
Microwave light and clock work but no heat
Could be one of the three door switches. If the fan turns on when cooking and no heat then the magnetron is bad. Most problems are the switches
Feb 20, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
Microwave lights up, turntable turns and fans run however food does not heat up. I have checked to ensure the power level is up which it is. Tried the express 1 minute as well as using the time mode and...
The problem is one of three things, the magnetron "common issue" the high voltage capacitor and diode can be a factor, all three work together in conjunction with the high voltage transformer to generate the high voltage that heats the food.
Mar 05, 2011 | GE JVM1850 1000 Watts Microwave Oven
Kenmore Microwave not heating. Turns on, lights, clock, etc.
The problem is one of three things, the magnetron has failed "common problem" or the high voltage capacitor or diode can be a factor, all three work together to heat the food. Depending on repairs the cost can be as much as a new microwave oven.
Feb 27, 2011 | Microwave Ovens
I need 3 light bulbs for this model
You did not indicate the brand and model number of your microwave.
Many use a regular 40 Watt oven bulb as a replacement.
Simplest is to remove one light bulb and take it to a retail outlet that has a lighting department and make sure your purchase the same type to replace all three.
Jan 31, 2011 | Microwave Ovens
Light under unit stays on
open the oven there are two or three safty switches near door one of the switch is for light if it is short then only light will remain on.by opening door light should come on set the time and hit start light will come again. replace that switch and it will be ok
Aug 07, 2009 | GE Advantium 120 Convection/Microwave Oven
Whirlpool Microwave after cooking fan on when door closed
Guess I'm an impatient person, took microwave to service center this morning. Hopefully, have it fixed by this afternoon. Thanks.
Jun 17, 2009 | Microwave Ovens
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
104 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
