Question about HP Pavilion dv6000z Notebook
Frozen computer My laptop has no battery life anymore it lives off a constant supply of electricty from it's charger. So if the cord is pulled out the computer turns off immediately. The other day i had half a dozen programs loading at once and the computer was having troubling responding to one or two. All of a sudden i bumped the charger cord and the computer turned off. So I tried to turn it back on but it won't go past the black hp invent screen that you see first when you start the computer. I've tried to press esc and f10 but it seems to be frozen... Can I do anything myself to fix it??
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 135 Answers
Try booting into safe mode and disable some startup items in the system configuration utility window. Another solution is to insert the OS disc and boot to the recovery console and type in fixboot c:
Posted on Apr 25, 2010
Computer say its always charging even when not on charger
Based on the symptoms I would suspect a failed lithium battery. Most people think they should keep their lithium batteries at 100% but that actually shortens the life (number or recharges). I always suggest that you should try and let your laptop run down to 50% before recharging. Leaving a laptop constantly plugged in results in the same outcome - constant recharging of small amounts so you can see that the 'life cycle' is related to the number of times you recharge and if you are constantly doing it then you will most likely be shortening the battery's useful life. Unfortunatley most laptops will not run without the battery so the user's only option is to run their laptops on battery and not plugged in to AC until at least 50% dissapation thus optimizing the battery.
Just in case you have not done this, try removing and reseating the battery. Jarring of the laptop can somtines alter a good connection but from what you said it is unlikely.
Jul 07, 2014 | ASUS G73JHA1 Notebook
Y samsung netpad mod N210 mains power light at the laptop constantly changes from green to orange and is not charging the battery if i remove mains power the laptop go off immediately
Have you checked your Cord, Verify that the cord is good by using a computer like your, make sure the power specs are the same. Or get a cord and try it with your laptop. Perhaps the jack is damaged in your laptop, pulled, yanked, tugged, you get the idea. If so replace the AC jack. Bad Battery? How old, mine lasted 4 years.
Nov 08, 2012 | Computers & Internet
My computer won't come on at all
Sounds like either a problem with your charger or the motherboard power pin, this is a common issue with laptops I probably install 2 or 3 of these a day. what happened is if the power supply cord constantly pulls on the ac plug going into the power pin if often breaks and seizes all power to the mother board. if thats the case the pin itself cost about 40 bucks new and a tech with soldering experience would perform about 150 bucks in labor. so about 190 if its the power pin, try replacing the charger first.
May 30, 2011 | Acer Computers & Internet
My Acer Aspire One was working correctly untill I powered it off yesterday. Now there is no charge indictor burning, and the power light stays out when pressed. And the netbook does not start up. So there...
Yes, it's either the charger ... the power connector ... the battery (not contacting well, or not charging anymore, or if a Li- Ion battery, it's depleted too low to start recharging anymore), or ... the power supply (circuitry) that's toasted.
Try removing and re-seating each component ... to see if the connection is the problem.
With the power charger inserted, try to power up ... and/or hold the power on for a while ... up to a minute or so, to see if it powers up.... and you get lucky.
Aug 11, 2010 | Acer Aspire One PC Notebook
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Charging my mac laptop
hi if it's a ibook or powerbook g4, you certainly have a broken part of your charger that stayed inside your mac... then you have to change the port and the charger
May 20, 2009 | Computers & Internet
Thanks
Do you charge it from an outlet of via usb cord? If from an outlet, the charger just might not work anymore, but the usb cord that you use to put media on the mp3 player will charge it also.
Sep 06, 2008 | SanDisk Sansa e260 MP3 Player
DELL 600M AC POWER CORD
The internal power supply of your PC is broken, it needs to be serviced.
Feb 13, 2008 | Dell InspironTM 600m Notebook
HP Pavilion dv6000z Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
