Question about Nixon District Watch
Nixon district watch won't start
I just bought the Nixon District watch in the states. The crown won't move and the watch won't start.
Thanks for your help
SOURCE: Nixon Watch band
Perheps this will help though it's not the same company http://www.allamericanwatches.com/site/626101/page/182605 Or get in touch with your local dealr you have a 2 year warraty on that watch http://www.nixonnow.com/za/NNS?PAGE=FAQ&MENU_ID=14
Posted on Jul 03, 2007
escapement
  • 2334 Answers
SOURCE: tighten wristband of the Nixon Watch , remove links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
Posted on Feb 10, 2009
escapement
  • 2334 Answers
SOURCE: battery change for Nixon Kink watch
You have to open your watch caseback. Undo the battery holding contact, get the battery out and memorise the writings on the battery. Buy exactly the same one and replace it in the backwards way you took it out.
Posted on Feb 28, 2009
escapement
  • 2334 Answers
SOURCE: how to set the time on Nixon Game over watch
Follow this link: http://www.nixonnow.com/manuals/index2.html This is all what NIXON is offering for download. Rate me, plz.
Posted on Jan 28, 2010
How to remove crown from Nixon the stand watch
Pinch the shaft from the inside and unscrew the crown
Aug 25, 2016 | Nixon Watches
Hi - i need a manual for a nixon The Housing - or how dot I set the time and tide on it
Hi here is the link for all of the nixon manuals
http://www.nixon.com/manuals/index3.html
Kind regards
Sep 12, 2014 | Nixon The Housing Watch
How do I reset the millisecond hand used in the stop watch function on my nixon Ride SS watch?
Try this:
Resetting Chronograph Hands:
Note: Some Nixon watches come equipped with a "screw-down" crown; the crown must be unscrewed by turning it counterclockwise before it can be pulled out)
1. Pull the crown all the way out to position 2.
2. Push the crown in slightly to position 1.
3. Push top pusher button to advance the second hand to line up with the 12:00 position
4. Push the crown back in. (Make sure it is screwed in if it is a screw crown)
Jan 02, 2014 | Watches
I recently bought a nixon newton watch and my crown fell off the other day. So now i can't adjust my time i was wonder can i replace the crown or do i need to get a whole new stem and crown?
if you still can see the stem near the hole of the watch, you only have to replace its crown. but if not you have to replace both. i hope i had been helped you.
Sep 01, 2011 | Nixon Newton Red Wrist Watch
Hello I have two nixon men's wrist watches that
just bring your watch to Nixon watch experts. they have spare and tools to repair your watch.
Jul 14, 2011 | Watches
I have a Nixon LowDown Tide Watch and the screen is staying blank, almost as though it is in a battery saver mode unitl i press any button and its display turns on for 3 seconds or so then goes back to...
Hey, this just happened to my nixon watch (I have the nixon housing - same setup as the lowdown) and what you have to do is simply hold in the light display button for about 3 seconds and the display won't disappear after the light times out.
hope this helps :)
Apr 09, 2011 | Nixon Lodown Tide watch
My new nixon 42 20 when i reset the chrono the second hand doesnt go back to zero it goes to 16 seconds past how do i sort this problem its annoying !
  • Undo & pull the crown all the way out,then
  • undo the adjuster button (the one underneath the crown)
  • push the stop/start adjust button one push at a time and it will move in slight increments,keep going till you get the second hand on the 12 mark
  • then push the top adjuster and it will go back to the 12 mark.
  • Push the crown in and wind your adjusting buttons up and you have finished
Aug 20, 2010 | Nixon 4220 PU Chrono Watch Black
I need a couple of extra links to my black and silver Super Rover
mcdevito75 here, BEST BET, look for a small watch repair shop in your area, chances are you"ll have to order these links from Nixon watch.
Jul 12, 2010 | Nixon Super Rover NIX0123
How do you set the time to the Nixon 51-30 watch. Also what can you do to stop the knob from coming all the way off when unscrewed?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Nixon watch manuals. To stop the crown to come off it must be screwed and secured onto stem. If you are not sure how to do that, visit your nearest watch repair shop and they will do it for you. Rate me, please.
Feb 26, 2010 | Nixon 51 30 Tide Watch
With "The Producer" Nixon watch, can you reset the main stopwatch hand to zero? It resets to +4 second position.
Pull out the crown to the first or second set position then press and hold down the start button. The sweep arm should begin to move into the right position. Once it is at 12:00 or 0 release the button and press the crown back in.
Sep 12, 2009 | Nixon Producer NIX0022 Wrist Watch
Nixon District Watch Logo
167 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
