Question about Weber Genesis Silver A Grill
The right side of the grill is much hotter than the left.
    Guru:
  • 1,051 Answers
The burners are clogged on one side. Remove the burners and make sure they are cleaned.
Posted on Apr 25, 2010
How to use the grill
grills are used with the front open
if it has a separate door open it, switch on the grill and select which tray level by the grooves in the side of the opening
closer up the hotter the cooking , the lower the more temperate setting
just turn on grill switch , open door and go for it.
Apr 12, 2015 | Ovens
Stuck valve
It is not unusual for the left side exhaust to be hotter. It hooks to the rear cylinder that has the least air flow and consistently runs hotter.
If the back pressure draws a dollar bill in when placed at the end of the pipe, this is typically caused by improperly closing valves.
Oct 19, 2013 | 1993 Suzuki VS 1400 Intruder
Only left side of burners working
If you have the Cal Flame burners that are straight, cast brass burners, there is a slot under neath the burners on the back end of the burners. This slot allows the flame to move from the left side of the burners to the right side of the burners. This slot in the burner will corrode shut and not allow the flame to move from the left to the right side. Sometimes you can scrape out the corrosion, and sometimes you can not. If you can't get the slot open, then you have to replace the burners. Cal Flame burners also have a reputation for warping.
Mar 04, 2012 | Cal Flame 4-Burner Drop-In Grill
My left burner is much hotter then the right burner on my 1504 Natural Gas Grill. Please adivise
It mat simply be a case of the right burner needs to be removed and thoroughly cleaned as well as the attached venturi valve. Spiders like to build nest in the venturi valve, clogging them so the so the air to gas mixture is off.
Jul 18, 2011 | Ducane Standard 1504 (LP) Grill
On 6910p no sound on left side speaker
There is no left speaker. The grill on the lieft is fake (just for decoration/design. Both speakers are behind the right grill
Sep 21, 2010 | HP Compaq 6910p Notebook PC PC Notebook
One side of the grill gets hotter than the other.
Is this grill new? How many burners are on this grill? Typically if there is a pressure problem, the farthest burner from the regulator suffers. Looking at the photo of the grill, the tank and regulator are on the right, which would make the left side burner weaker. The flames can be even all around each burner, but if the burner on the right has slightly taller flames than on the left, even increasing the pressure won't "even" it out, it would just make both bigger. It could be just the nature of the beast. If it was feasible and the left and right burner were identical, it would be interesting to see if switching the burners would make any difference. Check to make sure each burner's air shutter adjustment is the same and adjust each for the bluest flame possible. Look for spiderwebs, bugs, or rust debris and blow out with air compressor, if possible. Let us know if you need more assistance. Good luck!
May 18, 2010 | Weber Genesis Silver B Grill
My Weber gas grill is less than a year old. The
gas regulator make sure all burners are off when you connect bottle... the units have a leak sensor and will stop the gas coming out because it thinks you have a leak when you connected the bottle. now try hooking up the bottle again with all the burners closed incl. the side burner and the infa red. It will work o.k. then
Apr 07, 2010 | Weber 3820301 Gas Grill
Only the left side of the grill heats up. How do we get the right side to work again?
Make sure the grill is clean and the burner are not clog you can use oven cleaner to clean it
Mar 30, 2010 | Ducane 455 inch 2 - 3 Burner with...
How do I adjust the flame to burn hotter or more.
There are adjustment screw at the end of the burner tubes that allow more or less air to enter the burners. try opening or closing these screws
Jun 01, 2009 | Jenn-Air JLG7130A
Weber Genesis Silver A Grill Logo
148 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
