Question about Kitchen Ranges
Does anyone no where fuse is on kitchen aid stove
    Habit-Forming:
  • 193 Answers
3 places they may hide
1 remove back panel
2 inside grill on the back wall
3remove front kick panel
Posted on Apr 25, 2010
I have the stove on clean and it is beepin an showing FS or S5
NEVER use self cleaning on Whirlpool or Kitchen Aid. The HIGH temps will blow the thermal-fuse.
Jan 27, 2011 | Whirlpool Kitchen Ranges
How do I remove the built in oven to replace the
there are no internal fuses, chk your houses main power panel and stove plug to make sure you have 240 volts for proper unit operation
Nov 03, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchen aid electric stove does not go on
check the door lock switches on the door lock they get bent out of sdhape real easy
Jun 29, 2009 | KitchenAid KERC607 Electric Kitchen Range
I have a kitchen aid stove gas stove top.had a pro longed power outage(24 hrs) will not ignite auto matically any more must use matches.any suggestions?
check the outlet, perhaps it's its hokked to a GFI outlet somewhere else in the kitchen and the GFI outlet has tripped
Jan 11, 2009 | Jenn-Air JGR8875QDS Gas Kitchen Range
Stove top difficult to light
your gas jets are dirty.. clean them with a toothbrush (after everything is cooled down).. you can use the selfclean to clean the iron pieces that cover the burners..
be careful with kitchen aid self cleaning.. there is a known issue with the thermal fuses blowing quite easily on most self cleaning cycles..
good luck
tpug
Feb 21, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Kitchen aid stove problem
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Dec 03, 2007 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
77 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
