Question about Seiko Mantel Clock
The time and chimes are out of sync for our tempus fugit wall clock by 4 chimes does any know how to adjust it
  • Anonymous Mar 22, 2014
    I have a Tempus Fugit wall clovk that has Citizen Quartz on the face. (Roman numerals) The unit is run by battery. The pendulum moves and i can hear a ticking as normal, but the hands are not moving. Neither of the hands are obstructed. I can adjust the time with the dial on the battery pack/movement box, but that's where it stays, even though the pendulum is swinging and the clock is ticking. It's a beautiful unit, but would love to know how to sort this problem. Cheers Rob.
    Problem Solver:
  • 15 Answers
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
Posted on May 10, 2010
Seth thomas manual for models E658-E659and E662-E663 series floor clocks
Try Googling (seth Thomas)(*)(manual) without parens.
* E658, E659, E662, E663. Search models one by one.
Nov 15, 2017 | Seth Thomas Home
I have a daniel dakato tempus fugit clock and i do not know how to make it chime on the hour
Try Googling (daniel dakato)(model)(manual) without parens for instructions.
Jun 23, 2017 | Chime Home
Tempus fugit German grandmother clock has a very dull sounding strike on the hour. Is this normal?
Bugs in the bells?? The hammers may also be out of alignment and are staying ON the bell rather that doing a "strike." If there are small screws on, at or near the hammers, or the mechanism that attaches to the hammers. make SMALL adjustments each hour or day, writing down what you did to each, until it works properly again.
Good Luck!
Apr 02, 2017 | Home
Is there a way to turn the chime off?
It depends on what type of movement you have, not all clocks have the silent option. If it does it will have a silent or chime lever on the front of the dial or it will have a small hole marked silent or chime (on the dial again). If it has the hole you will need a small key to turn it.
UsedClockParts.com
Aug 28, 2016 | Home
How to get my Tempus fugit grandfather clock to stop chimmimg
Unless it has a lever on the dial that allows you to switch it to silent you can not.
UsedClockParts.com
Jul 14, 2014 | Home
I want to know how to set the time on a tall grandfather clock. It has a key but I do not know how to set it and I do not want to miss it up. On the front of the clock it says Tempus Fugit Barwick. I...
I have 2 GF clocks....
To set the time, first be sure the clock is wound (weights are in the up position). Next, be sure that the pendulum is operating.... The "click, click" sound should be spaced about evenly. If not, then change the height adjustment of the feet to make the clock level...then the click will even out. Next, using only your finger, gently move the minute hand in a CLOCKWISE direction until you have set the time. You MAY wish to allow the chimes to sound at each quarter or half hour mark as you rotate the minute hand - but it is not necessary. Just keep rotating the minute hand - and the sounders will catch up and chime correctly.
Jun 25, 2010 | Computers & Internet
Tempus fugit westminster mantle battery operated clock has 2 buttons under an H and 2 buttons under an M. how do I set the chimes? Amy Howard
I had the same problem but the solution is unbelievably simple. Just set the hands to the time desired by turning the round button on the housing. Now you mmust tell the quartz timer/clock (plastic rectangular mechanism) the same time as you have set the hands. In this way when the hands hit the Quarter hours/half hours and the hours, the electonic chimes will chime the correct time.
Ultra simple. The two hour buttons and two minute buttons represent a 24 hour clock. Example, how to set the clock to 2:50 PM. Easy, change the 2 PM to its 24 hour counterpart, i.e. 14 hundred hours.
Move the hands to 2:55. Push the first button once for 1, push the second button 4 times, push the first M button 5 times, push the second M button 5 times. Move the set button back to run and there you have it. 1455 Hours. Not it should chime correctly. As a tip, use a brand new fresh battery to try this out.
Feb 08, 2010 | Seiko Mantel Clock
Home Logo
1,755 people viewed this question
Top Seiko Home Experts
k24674
Jerry Greenberg
Jerry Greenberg
Are you a Seiko Home Expert? Answer questions, earn points and help others
