Question about RTO Atwood Water Heater - 6 Gal LP
Heater when switched for gas operation will send spark to ignitor and ignite for approx. 5- 6 seconds and go off.Will do this 3 times and lockout?
  • RTO Master
  • 6,674 Answers
Have you tried positioning the electrode closer to where flame is? That also senses flame to keep gas valve open, and if not sensing flame, with cause it to shut down. Clean it with a small brass brush, or similar, and make sure it's getting good flame from burner directed at it. Let me know if that helps. Do you by chance have a multimeter, or 12 volt test light for troubleshooting ?
Posted on Apr 25, 2010
Igniter on gas water heater only sparks once
First pull the ignitor wire off the ignition module...hold a screwdriver 1/8 to 1/4 inch away from the electrode pin on the module then turn the unit on to see if it sparks differently than what you described before you replace the ignitor.
Dec 19, 2013 | Honeywell Water Heaters
Hotpoint water heater the electric igniter won't spark
Copy following link for troubleshooting igniter, and troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#igniter
Add a comment and say what manufacturer appears on label.
Open link above and scroll to top for information about FV lockout.
Mar 16, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem Intelli-vent intermittently goes in lockout mode
Rheem does not post service manuals.
However AO Smith has posted relevant service manual:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Have you cleaned the air intake located under combustion chamber, and inspected for broken glass vial?
Rheem FVIR system uses glass vial that breaks if combustion air is slowed, and resulting combustion causes slow-moving venting of hot gasses, causing overheating that breaks glass vial.
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
Check gas pressure.
Replace gas control valve:
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Oct 09, 2012 | Water Heaters
I have an Atwood waterheater model # G6A-8E. I am having issues with no spark from the ignitor , I have used a long stem lighter to light the burner. It lights and burns well for a couple second seconds...
When you turn it on and hear the ignitor clicking, test for 12 volts at power wire to gas valve. If your not getting 12 VDC to gas valve when ignitor is sparking, replace module.
Jul 10, 2011 | RTO Atwood Water Heater - 6 Gal LP
The water heater red light keeps flashing rapidly on my Powervent 2 model 41VRP40N. It is not producing hot water and when I read the manual it says it needs more heat. What does this mean. How do I fix...
There are many things to check. The single most important test is for 24V at the gas valve after the ignitor is supposed tp be on. 19 V or less and there is either a bad ground or the ingition control board has failed. (Wire ground problems are a high probablilty)
Here is what the book says:
PROBLEM #1 - HOT SURFACE IGNITOR DOES NOT GLOW RED
(Remember to wait for purge time, 17/34 seconds, on models so equipped).
Possible causes
A. No main power
B. Faulty transformer
C. Faulty thermostat
D. Faulty limit switch
E. Faulty blower interlock switch
F. Faulty hot surface ignitor
G. Faulty ignition control
Solution
Step #1
Perform normal system checks of main power, transformer, thermostat, limit
switch, blower interlock switch, and replace faulty component.
Step #2
With power on and thermostat set at its highest position, check voltage
between "TH" and "TR" on HS780 ignition control. If 24 volts is not present
check output at transformer. If no, replace transformer. If transformer
checks out OK look at other controls in the 24 volt circuit I.E.: thermostat,
limit switch, blower interlock switch. Check for 120 volts between "neut"
(L2) and "120" (L1). Check for 120 volts at the ignitor across "IGN" and
"IGN" terminals on the HS780 ignition module. If 120 volts is present,
replace ignitor. If no, replace the 780 series module
PROBLEM #2 - IGNITOR GLOWS RED BUT MAIN BURNER
WOULDN'T LIGHT
Possible causes
A. Improper ignitor alignment
B. Faulty ignition control
C. Faulty gas valve
D. High inlet gas pressure
E. Polarity reversed
F. No earth ground
Solution
Step #1
Check for availability of gas at gas valve. Make sure the manual valve
upstream of the gas valve and the gas valve are in the full on position. Also
make sure gas is being supplied to the system at the proper pressure, too
high will lock-up the valve.
Step #2
Check proper polarity of "NEUT" and "120" on the ignition control by reversing
the wires, if reversed gas valve will not open. If this does not solve the
problem, replace wires as they were.
Step #3
Check for proper ignitor position.
Step #4
Check for a good earth ground by using a meter connected between L1
and furnace chassis. Should read 120 volts, if no, check and/or repair ignition
ground wire or ignition control mounting screws.
CAUTION POLARITY MUST BE OBSERVED
Step #5
Check for 24 volts at the gas valve terminals; "1" and "2" on a 7200 series,
"M" and "C" on a 7100 series, "TH" and "TR" on a 7000 series. If yes,
check wire integrity or change the gas valve. If no, change the 780 series
ignition module.
That is pretty much all of the troubleshooting required.
Thanks for choosing FixYa,
Kelly
Feb 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
The electronic ignition on a gas water heater will not heat up and glow red to ignite the gas to heat the water atwood r/v water heater
You won't see any red glow until the burner ignites and burns for a while. Its only an ignitor and flame sensor, not a glow plug style.The ignitor has to provide spark for gas to ignite, then it also senses the flame and keeps gas flow coming. What exactly is happening when you turn it to on?
Jul 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
New gas water heater pilot light will not ignite
Hi .. if this is a brand new heater, then you probably need to have the gas line bled. This means getting all the air out of the gas line feeding the burner. This can be done by constantly trying to light the burner or poilot . or it can be bled down by a HVAC tech.
Apr 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Atwood GC6AA-9E water heater isnt working properly
The ignitor is also a flame sensor. If it's not working to ignite, good chance it's not sensing flame to keep gas flowing as well. Could also be board.
Sep 09, 2009 | RTO Atwood Water Heater - 6 Gal LP
Lock out light
these furnaces have a sequence of operation , 1 thermostats calls for heat,2 purge fan checks flue is open and not clogged ,3 checks to see if hot plate ignitor or spark ignitor is on 4opens gas valve 5 checks for flame and allows valve to stay open 6 checks for temperature rise and brings on fan , if any of the process is not there or interrupted trys 3 times and defaults to lockout , that is the best answer with out knowing what type you have , hope i helped
Nov 09, 2008 | Water Heaters
RTO Atwood Water Heater - 6 Gal LP Logo
118 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
