Question about Maytag Neptune FAV6800AW Top Load Washer
Filled with water and won't drain
The washer overflowed into the laundry room. The lid was locked. I have been able to unlock the lid and remove the clothes but it is still filled with water . Is there any way to get it to drain?
  • 526 Answers
You’re in the FAV6800a/FAV9800A forum so I’ll assume it’s one of those models. You can do this from Service Mode the method I prefer less messy, just follow this process it’s in the SM but I typed out for ya.
To pump out the excess tub water while failing to complete spin cycle.
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with the off button or hit the Presoak key.
Sorry to hear about the over fill. May be you have a stuck water valve or stuck pressure switch. If you want some help just verify the Model type…..Rich
The Service Manual for reference. Sears Parts Direct for reference.
Posted on Apr 25, 2010
  • Maytag Master
  • 43,501 Answers
You can use a hose to siphon the water out into a bucket..
Here is a tip that I wrote... it will give you some things to try...
http://www.fixya.com/support/r3867591-washer_troubleshooting_water_not
heatman101
Posted on Apr 24, 2010
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
CHANGE DRAIN PUMP WASHER
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
Water was overflowing over the top and flooding the laundry room
If it was left in the reset position then it could absolutely pushed the diaphragm in the air switch to a point that the contactor couldn't reach it. Set it on a large load, let it fill and watch it. If it starts to overflow, pull the plug out, if it continues filling, you need a new water valve on the washing machine and if it stops then you need a new level switch
Jun 16, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Keeps on filling and wont drain
please follow the steps which i give to find and rectify the mistake (1) First check the wash load/laundry. If it is unevenly distributed in the tub making it unequal, rearrange it, close the lid again.
(2) Make sure your washer is leveled and you have filled sufficient water in the tub for that size of wash load/laundry. Insufficient water can make imbalance.
(3) Make sure the power cord/cable is plugged into the working electrical wall socket.
(4) It is better to check the appropriate circuit breakers or fuse of the fuse box and reset if necessary.
(5) Inspect the drain hoses and remove any bends. Inspect the drain system, too - if it's clogged.
(6) Then close the washer lid and pull out the knob to start it. For your safety, the washer will not spin unless the door is closed.
(7) Excessive foam can also cause this problem. If you find it to be the solution, rewash the clothes with plain water. For future, ensure use of correct amount of detergent with low-foam.
(8) It is possible that the lid switch, that prevents the washer from spinning when the lid is open, could be malfunctioning. If that happens, a built-in mechanism – brakes will be applied and washer will stop washer operations until the lid switch is repaired/replaced.
Jun 13, 2009 | Washing Machines
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
GE WJXR2080T2WW Washer Fills with water - then stops
older machine would have been easier to fix ..remove front ck small hose to tub left side remove hose and clean crud from end as much as possible if still overflowing replace water level control..new machine may be timer or lid switch not closing properly remove front to acess lid switch on right side
Jul 22, 2008 | Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
123 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
