When the washer is full and starts to wash the water still flows in to the washer and I have to turn the water off to the machine and it even runs in the washer after its off .
    Passionate:
    Visited the website for 10 consecutive days.
    Champion:
  • 206 Answers
Bad fill valve
Posted on Apr 24, 2010
When i turn on the washer it won't start& water keeps flowing into washing machine. does the water flows or not suppose to flow into the washing machine from the inlet valve?
water into a washing machine is controlled by a tube in the side of the bowl up to a pressure switch
as the water level rises in the bowl, pressure in the switch is built up until it overcomes the setting that you have made for a water level on the wash size selection switch
at this point it turns off the inlet solenoid switch and starts the wash cycle
If the water solenoid is burnt out then water will continue to come in and over flow the bowl but it should be washing as well
If the water is not stopping then check for a disconnected hose to the switch or ma hose full of water
failing all that get a washing machine mechanic in
Apr 18, 2015 | Maytag Neptune MAH5500B Front Load Washer
My Electrolux front load washer over flows even after added new pressure it also indicate no water on display
the solenoid is sticking at least that's what I call it you can turn the water off once its full wash but stayed dead on it so you can turn the water back on for rinse cycle if its a computer operated washing machine get rid of it and buy your older model whirlpool a Roper anything with compatible Parts I found many of my washer is on the side of the road and fix them good luck with yours
Feb 26, 2015 | Electrolux Washing Machines
Washer starts to fill at power on
Pressure Switch is defective or tubing going from it to tub is stopped up
Oct 10, 2017 | Whirlpool Washing Machines
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Water won't stop running even when we turn the machine off it slows a little. i have to turn the water off to stop the flow of water.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Sep 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water keeps running into my washing machine. Even
Water valve is stuck open, probably by lime or calcium build-up. Proper fix is to replace the water valve. How old is the washer?
Jun 11, 2009 | Washing Machines
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
