Question about Toshiba SD-3960 DVD Player
How to operate
I was given the dvd player without a manual. I have the connections hooked up to AV2 connection and it runs but I can't figure out how to get the picture to show on the TV. I would appreciate any help you may be able to give me.
  • Toshiba Master
  • 5,390 Answers
  •  Grubhead
    Grubhead Apr 24, 2010
    PS It's under Resources (click then right click the pdf file to download)
How to hook up my dvd player to the t.v.
Hello
You haven't given any specifications about your tV here. Anyway, you can hook up the DVD player to TV using an AV cable. The AV cable will have three cables together with two RCA connections at each end of each cable. Look at the colour of them. Usually one Red, one White and an other will be yellow. Just connect them to the sockets of both DVD and TV accordingily, and switch ON both devices, select the tV input to AV1 or AV2. If all the connections are correct, you will see the logo of Mitsubishi on TV screen. This is the picture of AV cable. OK.
Nov 08, 2011 | Mitsubishi DD-8030 DVD Player
My dvd player will not work when hooked to tv. I
The video connection on the side of the TV is for AV2 composite video input, you need to use the remote control SOURCE button to select the input source to AV2 to see your DVD, Yellow plug is for composite video, Red and White for the audio, please read your manual for more details.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 18, 2010 | Spectroniq PLTV3250 32 in. LCD TV
I have recorded some programs on Sky+,and want to copy them onto dvds. I have been given A DURABRAND LEDVDR0702 with NO MANUAL. If you can help that'll be great.
If you connect a scart lead from the sky box,the one marked vcr,connect the other end into the dvd in the one marked av2.You then select av2 on the dvd,put the sky on play and the dvd on record
Nov 30, 2009 | Televison & Video
I just bought a second hand sumsung tv with a vrc attached. it has A/V connections but for some reason i cant hook it up to my dvd player...not sure WHY!?
connect up your scart lead, from the scart socket on dvd player to the scart socket on tvyer. There are usually to sockets to connect to on the tv, it will be AV1 or AV2. To view dvd, press source button on tv remote to select AV channel you have connected the dvd played to.
Aug 15, 2009 | Samsung Televison & Video
DVD is hook up and no picture on the TV.
You have to make sure that the RCA cables are properly connected to the TV. Check the TV/Mode if it's set to AV1 (Audio/Video1) or AV2. You may check the TV remote to set it to AV1 or AV2.
From the DVD, the cable should be connected to OUT. And on the TV...video and audio should be connected to IN.
Apr 05, 2009 | JVC XV-S300 DVD Player
Have a Sanyo DP42828(42"). My Satellite is working after the card resetting itself. But which 3 holes do I hook the (RED, YELLOW, and WHITE) for the dvd player?
dems,
Are you reffering to your DVD player to be conected to with your TV screen?
For DVD player connection the 3 colored RCA jack socket are:
YELLOW = video out
RED and WHITE = Audio out (left and right channels)
to hook up to your screen, at the back of the screen or side of it you'll see RCA socket indicating "AV1" "AV2" AV3" this are all Audio/video inputs where you can hook up all you A/V device or game consoles. These inputs also have the same 3 colored socket (yello = video red/white = audio)
connect your DVD player to any of this input following the same color code.After connecting the cable, select the input where you hook up your dvd player. Do this by pressing "A/V" buttons in remote commander of your TV. continously press this button until it reaches the exact location where you plug your player ex. AV1, AV2,AV3
note: in some cases the remote commander doesn't indicate this A/V button but a picture of a box having a arrow pointing inside the box.
cheers,
mark
Jan 05, 2009 | Sanyo DS31590 31" TV
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Hooking up a magnavox MWD7006 DVD player to a APEX TV
honey and guest: connections: Red, white, and yellow composite from out of cable/sat box to in of this dvd, and then a 2nd red , white and yellow cable from out of this player to in on television. Every television calls the correct channel something different - make note of where you plug the r,y,w cables to TV -- it may be labelled video1, video 2, av1, av2, input1, ext 1, etc. Turn tv to correct input/av/source/video channel. Call 1-800-605-8610 for further assistance.
Jan 13, 2008 | Philips Magnavox MWD7006 DVD Player
Hooking up dvd
Brad, AV-1 INPUT, be advised this will use up the AV1 port so if you have another item that uses regular AV cables you`ll then have to use AV2 for the video in and L&R audio in, enjoy, BMW Rider
Jan 07, 2008 | Philips Magnavox 27MT5405 TV
Toshiba SD-3960 DVD Player Logo
213 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
