Question about Olympus FE-190 Digital Camera
Olympus FE190 Digital Camera
I own this camera, but I need a manual. Where can I get a manual?
I own the olympus FE 190 but have changed computers and can't find my CD to download the software. Can you help?
Posted on Oct 13, 2008
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 230 Answers
Best to check for the Olympus Website and download a manual of the said camera.
Posted on Mar 24, 2008
2 Suggested Answers
  • 11967 Answers
SOURCE: lense stuck
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 29, 2010
Need the software to download photos from my olympus FE190/X750
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as iPhoto on Mac or Windows Photo Gallery and Picasa ( http://picasa.google.com ) on Windows.
Sep 13, 2011 | Olympus FE-190 Digital Camera
I need a driver of olympus FE-20 digital camera
Here is the official link from Olympus website http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1392
You can download the driver for your Olympus FE-20 digital camera including the user's manual in .pdf form.
Dec 27, 2010 | Olympus FE-20 Digital Camera
I need to find a users manual for the Olympus SP-600UZ Digital camera.
You can download the user manual for this camera from this link, just click HERE.
Oct 20, 2010 | Olympus SP600UZ Digital Camera
Need a new instruction manual for our Olympus Digital FE 140 camera
Hello. Click the link below to download the 108 page manual for your camera. Save a copy to your computer for future use.
builderdale
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/bman_fe130_e.pdf
Mar 03, 2010 | Olympus FE-140 Digital Camera
Need to download olympus fe-140dig.compact camera Service Manual
Well you can download the manual in pdf format from here: http://www.retrevo.com/support/Olympus-FE-140-Digital-Cameras-manual/id/200bh637/t/2/..................................sodeep
Aug 19, 2009 | Cameras
Olympus om-2 cvamera lenses
You are able to use your old OM lenses with a new Olympus digital SLR camera. You will need to purchase an MF-OM 1 lens adapter to be able to connect these lenses to the digital SLR camera. Also when using these lenses you will only be able to use the camera in manual focus mode as these lenses are not capable to shhot with an auto focus mode.
Apr 06, 2009 | Olympus FE-330 Digital Camera
My daughters olympus FE190 when switched on asks you to Format or Power Off. If you choose Format it switches itself off and if you choose Power Off is then gives you Card Error. Does this mean the...
The largest xD card which can be used in this camera is 2GB. If the card is larger than that then it wont work. This camera has both internal and card memory. Try using the camera without the card or with a smaller card.
May 14, 2008 | Cameras
Fe-170 olympus sound
From the specs i've read on this camera, it does not record sound in video clips taken.
The FE180 and FE190 do record sound.
Sorry for the bad news.
Mike
Nov 04, 2007 | Olympus FE-170 Digital Camera
Olympus FE-190 Digital Camera Logo
247 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
