Question about Kenmore HE2 Plus Front Load Washer
Front load Kenmore w/undrained water...
So, I've read these posts about the water standing in the washer and my door is locked; I've tried 'drain and spin' several times, but it keeps seizing up and the lights all flash....took out the drain hose (drains to pipe in wall) and moved down so gravity will assist, but I KNOW what the problem is, i washed a load of like bathroom rugs and some dirt or rubber backing must've clogged some outlet!
NOW...I read to take off front panel..ok but what kind of screws are those?! Not like phillips or flat head, they must need some socket thingy? What do I use to unscrew these dang little screws that I have to lay down to see? I DON''T KNOW!! Help....i can't call in repairman....
    Habit-Forming:
  • 120 Answers
You need a t20 bit you can buy them at any auto part store
Posted on Apr 25, 2010
Kenmore front load clothes washer fills with water and stops. No error code and door is locked. 2007 model, we tried unplugging and draining. We can't see model number because door is locked. Help!
Justin, check or by pass the lid switch if it has one, with a insulated jumper wire.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Kenmore Washing Machines
Maytag Front load Washer. "SUDS"
Clean the drain pump basket. http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
Hi! We have Kenmore Elite he3t. We noticed water in the washer today after a complete cycle so we ran the rinse and drain command on it. I tried to begin a new load on a normal wash cycle and it will...
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore elite model # 110.45088400. We set a cycle, washer starts beeping and reads F then blinks to DL. We hit pause to clear then try to restart while it makes clicking sounds and it continues to read...
'DL' stands for Door Lock error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 24, 2011 | Kenmore Elite 45986 Front Load Washer
F- code is on door is locked
Use a wet dry shop vac and attach it to the end of the drain hosse to remove any standing water once the water is removed the door should unlock. then check the drain pump and hoses fro anything restricting or bloxking the drain pump make sure to remove the hose from the front and or side of the drain pump.if you do not find anything then you may need to replace the drain pump.possable door lock and or communication failure with the main control board.
Nov 03, 2010 | Kenmore Elite 45986 Front Load Washer
Door is locked code F21 wont run or cycle or empty water
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Jan 13, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore elite washer will not drain the water in its drum.
Press & hold 'end of cycle' button right of panel for 3 seconds, power shd be on. And wait for a couple of minutes to try door. Possible your filter or pump is clogged. Should be a hose in front below panel to drain water.
And rate me nice plz, way of saying thk'u.
Mar 26, 2009 | Kenmore Elite 45986 Front Load Washer
Non-stop draining at whatever cycle selection
Is your drain pump constantly running? If it isn't, check the standpipe (drain pipe) and make sure you don't have your drain hose shoved down in the pipe too far or the top sealed off. The stand pipe needs an air gap to properly drain, or it can siphon water from the wash tub. Symptom: Washer continually tries to fill or slow fills, but water won't stay in wash tub. Double check your drain line to be sure. It could be a simple fix.
May 16, 2007 | Kenmore 46462 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
122 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
