Computer problems How do i fix this problem with my computer? When i am log on to my computer it comes up on the screen saying Stop Default search Attempt blocked. dsca.exe- Error A Fatal error occurred However, mscorees.dll could not be loaded to display the Appropriate error message. Please reinstall the .Net Fram work. I don't know what this is? Do i have to remove anything from my computer? Please give some instructions what to do.
    Genius:
  • 1,913 Answers
Remove your unnecessary programs from pc.and remove which u download from internet.
also scan your pc with avast,quick heal and symantec with update definition
run chkdsk utility
Posted on Mar 23, 2008
SOURCE:
Google comes up 5 times when I log onto Internet Explorer.
Tools > Internet Options and remove the extra entries for homepage.
Mar 19, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Change password wireless
Go to a computer that is hooked to the same network, and run the CMD prompt, type, ipconfig /all a bunch of numbers will come up, one of them will say Default Gateway, that number will be the IP address of your router, 9 out of 10 chance either 192.168.1.1 or 192.168.2.1 or 192.168.1.254, put that IP address in your web browser address bar, not the search bar but address bar and press enter, a login screen should come up, you can look your up depending on make and model, but most default ones are admin and password or something similar, once you log into router, just hit wireless section and you can see existing wireless code
Dec 30, 2013 | Computers & Internet
When turning on it will only go to a blue screen says go to safe mode or get tech support but even in safe mode it will only go back to blue screen. Can't download anything or do anything. At the...
Try uninstalling a few unnecessary programs
Just run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is 100%totally free to use
http://download.cnet.com/ccleaner/
hope this helps you
Jul 24, 2011 | Computers & Internet
I have almost same problem. This problem start one time when I using my computer. Computer always stop after trying restart, sometimes start normally and stop after few second. And now when I start...
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
also you might download and use this registry cleaner it is totally free to use
another one of the possibile reaons is
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hope this helps
Feb 25, 2011 | Abit KV8 Pro Motherboard
Keep getting a memory dump error
this problem only can fix by reinstall your computer operating system (windows)
Feb 22, 2011 | ASUS G51JXA1 PC Notebook
Computer loading up but not logging on..
This has happened because of a Microsoft update:
In Safe mode (F8 at boot up)
Start-search for cmd
With search result -cmd- right click choose option Run as Administrator
type in- net user administrator/ active:yes
type- exit
restart- pc logon screen should show administrator account
if you can logon through this account, alter any accounts you want through control panel
Apr 21, 2009 | HP Pavilion dv6000z Notebook
Cannot close controller to allow re-install of winfax pro 10.02
Control-Alt-Del and end tasks Wfxctl32.exe, wfxsvc.exe , wfxmod32 ...and faxmng32.exe
This can be any number of problems, like corrupt logs, too many entries in your default log structure,. You can check this link regarding rebuilding your logs:
http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=Help;CODE=01;HID=30
WinFax Tools has many fixes for WinFax that are automated.
http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=ST;f=17;t=412
Jan 09, 2009 | Symantec WinFax Pro for PC
Startup problem
some other errore should come with this other wise try entering bios setup at boot then enable default setting. thyen restar yr system if it still continues, replace the ram and see. if that doesnt solve yr problem then u format yr system it should be ok.
May 24, 2008 | Dell Dimension E310 PC Desktop
Default message when logging on
Hi
Pls type 'msconfig' in Run window in XP ir in 'Start Search' in Vista and once you get to the System Configuration Utility screen, go to the Startup tab abd there uncheck the option 'Realtek High Definition Audio'. Click 'Apply' and then close it and restart the computer.
Once you do this, it will not bother you again.
Feb 29, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
57 people viewed this question
Ekse
Alun Cox
