I have a toshiba theaterview rear projection TV. When I turn it on I hear a click and then a double click inside the TV. Then the power light on the front starts flashing continuisly and I get no picture or sound. None of the buttons will do anything including the power button. If I unplug it from the wall it will start all over again. I started having issues with the TV about 4 months before this with the picture going black from floor vibrations still had sound though. usually I could get it back on by stomping on the floor or tapping the side of the tv.
  • 1 more comment
  • dj303dj3 Apr 25, 2010
    I started pulling out the circuit board unplugging a few connectors and sliding out the whole thing. But I decided to stop and put it back together and gave it another try and it is working for now. But it would intermitantly work before also. So I am not convinced the problem is solved. Is there anything I should check out while it is working right now? Or do I have to wait for it to fail again?
    The model # is TP61H60. manufactured on dec. 1998
  • dj303dj3 Apr 28, 2010
    It stopped working again. guess I'll have to call in to a expert
    President:
  • 1,768 Answers
1.You may be looking a fly back issue/
2. the fly-back transformer may be arching and needs replacement.
3. A tech will be able to determine this with test where the issue is on the main board.
I hope this helps.
Posted on Apr 24, 2010
  • 19,396 Answers
Hi .
The clicks that you hear is an internal device called protection circuit that is shutting down the TV, and forcing the PSU to +5V low only to keep the TV in standby.
That is called protect mode.
If the TV stays in stand-by, with the LED light on, but does not respond to remote, or to the buttons on the chassis, then that means that the TV has gone in protect (safe) mode because an internal fault had been detected.
In that case the TV is usually faulty.
Common faults on this model that can cause PSU clicking concern PSU board, main controller board, and ballast board.
If the TV problem is affected by wacking, then the problem is usually a broken contact caused by a bad soldering joint.
The parts must be tested before replacement. Less common faults could cause the same problem.
When the TV reacts positively to wacking, testing is done reading continuity on all contacts to find cold solder joints (broken contacts on printed circuit board soldering).
Try first disconnecting all connected devices, and leaving the TV disconnected from power for about 30 minutes. To drain power completely.
You can follow the basic troubleshooting on this article: Why my TV does not start up and remains in...
If that does not work, contact Toshiba, ringing the support number listed on the owners manual to get the TV repaired by a licensed technician.
Parts for Your Toshiba and Service manual may be available here.
Regards.
Posted on Apr 25, 2010
I have the Toshiba Theaterview. Was watching it when I heard a sound and the screen went black. The Red Light will come on and glow steady and you hear it click when you try to turn it on or off but...
Something is causing the TV shut down or go in to 'protect' mode.
It is unusual to actually hear a component inside the TV go bad, but you obviously did. Probably in the main power supply or something that normally uses a higher voltage in the TV since you heard it..
Jan 25, 2015 | Toshiba Televison & Video
Have an older Toshiba theaterview TV, when turn on, we have no picture, no sound, just black screen and blinking red light that just continuously blinks.
Theaterview suggests a rear projection--in that case it most likely is in the convergence circuit--unsolder chips (convergence) and see if set turns on.
Some of their regular TV sets (picture tube) if the light is just blinking means the same thing=shutdown because of a short/problem but a model number would tell me which you have.
May 23, 2012 | Toshiba Televison & Video
My theaterview tz61v61 has no sound or video i checked the fuses on the on board circuit and, with the ones i could see, seem to be fine i have little knowledge of tv ciruits and tv troubleshooting. ...
U get all solid LED lights indication front of bazel panel of the tv?U got power LED light flashes or no LED light at all?Check for DM power supply board,for dying leakage bulges up capacitors on it tops or puffing up on it tops.Replaced dying capacitors."LAMP"LED light indication on stay on or flashes.The projection lamp is dead,require changing,also hear alot of clickings too.Mean the the board call the Ballast board is also dead,require changing too.This Ballast board help to ignite the projection lamp.
Aug 05, 2010 | Toshiba TZ61V61 61" Rear Projection...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Toshiba theaterview 51inch
I had this happen. The power cord in the back of the T.V. ended up being loose. I fixed that and have'nt had a problem since.
Jun 09, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba TheaterView
Called Tv tech. He said it was the power supply connectivity. common problem in rear projection Tv's. Cost to replace was anywhere between $300.00 and $400.00 dollars. Time for a new tv :-(
Feb 21, 2008 | Toshiba 50A60 50" Rear Projection...
Toshiba theaterview
What is the model number?
Jan 03, 2008 | Televison & Video
Toshiba theaterview tz50v51
my guess would be flyback however your lucky you might be able to see a burnt spot on the board giving you a better clue.
Nov 25, 2007 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
