Question about GE AGQ10AJ Wall/Window Air Conditioner
Wont turn on
I checked everything. i plugged it in checkd the breakers it still wont work
    Novelist:
    Champion:
  • 246 Answers
If it's a 110 volt AC - you could try plugging another electrical device, i.e. hair dryer into the outlet to see if the outlet is working or not.
good luck!
Posted on May 04, 2010
We have a 2001 presidential 5th wheel it is hooked up and plugged and everything works but the lights. Is there a separate switch to turn these on?
There is probably a breaker box in the bedroom closet behind a panel. Look elsewhere if not there and check the breakers when you find it. You may have a short circuit somewhere and the breaker opened. Or maybe even a failed breaker. Check for voltage at the breaker itself. Don't assume the breaker is getting power.
Feb 03, 2017 | Holiday Rambler 2010 Presidential 36RET
The heat in my 2003 chevy tahoe doesnt work. The motor wont spin. I've checkd fuses & the wire from the resistor to the blower motor. All have power. Ive hook a neg/pos charge to the motor & it spins.
It has an internal card fuse which sits in the bottom of the blower unit.these get condensation and rust so the contact strips corrode over time.you remove by unscrewing one Philips screw and pull the fuse card out...inspect.i fixed mine by solder wire bridge across the breaks but if you can source from breakers or eBay all well and good.
Apr 01, 2015 | 2003 Chevrolet Tahoe
Everything went out
you blew a circuit breaker...find fuse panel and reset breaker. It will be the one that is tripped
Apr 05, 2014 | Maytag MMV5207BAW Microwave Oven
My right front turn signal wont work, the dash board light came on telling me i need a new bulb i put one in and it still does'nt work . I checkd all fuses and they are good , me right rear turn l
are you sure that you put the right bulb in? Some of these bulbs look very similar, (like a 3057 and 3157 or 3156) but they are different. A customer came in with this problem and the problem was that they put a bulb with a single filament in when it was supposed to have a dual filament. the bulbs looked the same and they just grabbed them off the shelf instead of asking the parts guy what their vehicle called for.
May 27, 2012 | Cars & Trucks
I have tried everything , check breaker, check fuse nothing helps why wont my dryer turn on?
check your cord or plug ,
check the dryer switch,
or check the fuse inside of your dryer.
Mar 07, 2011 | Crosley CDE6000 Electric Dryer
I have have my sunbeam electric heater model number sfh090 for a month now and it just stopped working and wont turn on or anything! i tried leaving it unplugged for a while then plugging it back in but...
Have you tested the receptacle that the heater is/was plugged into, to make sure it's working and a circuit breaker hasn't been tripped?
If not, plug a lamp into the receptacle to see if it works. If it doesn't, check your home's circuit breaker panel for a tripped breaker. If you find one, make sure there's nothing still plugged into the offending receptacle and reset the breaker. Then, plug the heater in and turn it on. Does it trip the breaker again? If it does, there's some type of short in the electrical system of the heater. If it doesn't trip the breaker, but still doesn't work, return it to the place of purchase for a replacement. However, you must have your Proof of Purchase Receipt to do this.
Hope this helps solve your problem.
Feb 17, 2011 | Sunbeam Heating & Cooling
Where is microphone input on emachine t5062
hi scott, this is the back of your computer:
here is the back panel of your computer, with labels...
hope this helps out.
regards,
voodoo
Apr 20, 2009 | Computers & Internet
I have a 1999 mitsubishi chariot gdi. the problem is it starts but cuts out within 10 second start. The car is also running to rich & the spark plugs are black. we had it scaned & the airflow meter...
I would have the car plugged into a scan tool and check the data screen for the coolant temp sensor to see what it's reading.The sensor should be reading around the same temp.as out side the car when the car is cold or same temp as the temp gauge if the car is warm.If it's reading way too cool it is mostlikely your problem giving it way to much fuel.
Aug 23, 2008 | Mitsubishi Passenger Cars & Trucks
GE AGQ10AJ Wall/Window Air Conditioner Logo
135 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
