Back to:
Tags:
Pantech Duo Smartphone
Pantech duo problems (by 7 users)
posted by braeburnAK on Mar 23, 2008
hi there,
i have a pantech duo, and the screen is stuck on the at&t screen? it wont let me get into the main phone screen..i thought about deleting all the files off the phone and putting factory setting files back on it? as in resetting the phone to the way it was? however, i can find a copy of the files anywhere to do this? ive taken the battery out and the phone will start and turn off, just not get past the at&t screen. previous to this? i downloaded a program from download.com so i could edit my home screen settings? also a photo contact option which stopped working, which is when i turned off the phone and it wouldnt restart again. it said there was a file missing to start contact list. i can access the files in the storage and the phone, so like i said..i thought if i could only have the files to restart the whole phone from the beginning, and try and start the phone that way, it might work. anyways..im out of options and im freaked out i broke this stupidest $500 phone!! please help in anyways u can...sorry if this message either gave to much useless information or not enough useful information. thanks for ur help..
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by Dontresm, posted on Aug 07, 2008
I have the cell phone hooked up to my computer and it won't change from the at&t screen to the main screen
Comment by metooatl, posted on Aug 06, 2008
what is a sd card??
Comment by elysechuvala, posted on Jul 01, 2008
My phone is stuck on the AT&T screen as well as won't do anything else.
Comment by Guest, posted on Jun 18, 2008
My pantech duo freezes at the AT&T screen
Comment by Sean_Tex, posted on May 15, 2008
This dame phone freezes constantly. I have exchanged it once because the "FN" key didn't work but the original had all kinds of problems with getting email and accessing the web. Now this new one freezes and I have to reboot to get it working again. Then it can be working fine and without notice it sends all my incoming calls to voicemail but I don't get the new voicemail signal, or I call out and it ends the call immediately. Not to mention the poor camera.
Solution #1
posted on Jul 27, 2008
Not Rated (0)
psu_07_4life
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
My Phone had the same problem. Atnt said it happens when there is too much data on the phone. You can try soft resetting it which is taking out the battery. There is also hard resetting which takes everything out but I didn't want to do that so I'm not sure how it would be done. I solved my problem by taking out the SD card and turning the phone back on. Then I deleted files in the phone that I don't need. After putting back the SD card I deleted files off of that too. Now it seems to work fine.
good luck
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on pantech duo problems:
I don't want to Accept this solution
Solution #2
posted on Jul 08, 2008
Not Rated (0)
caitichelle2
Rating: 0%, 0 votes
the camera on mine wont work. its just a black screen and wont take pictures.
Thank You!
Can you Help with these PDAs problems?
When I first plug my phone up it starts to charge fine,...
My phone will not load. It will not even load my...
hey over the time that ive had my phone it just started to...
I dropped my phone and the screen broke. So now all I see...
ive been charging it and playing with it for about an...
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Apr 28, 2008
same problem
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
