When I turn on my compuer, it stops at displaying "Detecting IDE drives ...'. If I unplug the CD drive ribbon cable from the mother board, the boot-up process will proceeds. Doesn't this mean the CD drive is damaged?
    President:
  • 1,851 Answers
No, not at all. It means that there is a conflict between the hard disk and the cd drive. Please refer if the connection type is with IDE cable (a flat, wide, 40 pins cable) or SATA (a small, collorfull, with few contacts at the sockets) in order to guide you further. The model of the motherboard would be helpfull too.
In case of a problem or clarification, don't hesitate to post me a reply.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Apr 25, 2010
Unpluged small ribbon cable from mother board installing hard drive need to know where it plugs in
If it's an IDE cable it goes into the IDE 0 or IDE 1 on the motherboard.
It's your primary drive so it should go into the lowest number.
If it's an sata drive the and it's your primary drive it goes into the lowest numbered sata port on the motherboard.
May 24, 2012 | HP Computers & Internet
Re built XP system on a WD ide drive - worked fine. When I added a 2nd drive (a Hitachi deskstar which works fine on another system) the system hangs after detecting drives. Both drives' details are...
Please try attaching the desktar at a different cable aside from the master, use another cable,attaching it to another IDE cable. In short, dont have the WD and the deskstar on one IDE ribbon.
Oct 20, 2010 | Gigabyte GA-8PE800 PRO Motherboard
Can't enter window
check you cables from drives to mother board make sure they are all pushed in tight
and check the jumpers are set properly on all your drives then retry if it deosn't work you might need new motherboard or one o your cd or hard drives is faulty
Jul 09, 2010 | Gigabyte GA-K8VM800M Motherboard
What is this system ide or ?? looking to purchase a hard drive (500gb) and a new CD & DVD burner.. Just don't want to buy the wrong item.
What mother board is it? you have sata and ide drives.. new technology is sata which is connected with sata cable to *********** board and appropriate pover coard, the older teconlogy is ide, which is connected with ide (master slave) cable frm you motehr board to you drive... just post what mother board and i could be more specific...
Jun 28, 2009 | HP Pavilion a705w PC Desktop
How do i install a second writable disk drive???
aloha...this can be done, IF your computer has the expansion capacity. what kind of computer are you using?
Mar 17, 2008 | AOpen : CDRW 52x32x52 Beige Color Retail...
Ribbon installition
Is it ide or sata drives you are using?
Guessing ide as sat have no jumper but best to check :)
Sett all the 3 drives jumpers to "cable select" and then just make sure you hard drive is in the master ide channel and on the end of the cable.
Jan 04, 2008 | Computers & Internet
DRW-1814BLT compatibility with IDE hard drive
put hard drive as Master. dvd rw as slave!
if DVD comes with sata then just put hard drive as master.
configure it on the bios setting!
if it still don't detect it
try replacing IDE cable and sata cable!
Nov 15, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
How can i make my CD ROM display
Open the case and check for IDE CABLE if it is correctlly connecter to the mother board.CHeck for the JUMPER if it is SLAVE OR MASTER! if still not working change IDE cable!
Oct 18, 2007 | Gateway 450ROG 15inch SXGA+ LCD Display-...
Had some problem with connecting the DVD drive to the PC
Depend on what you have in your system already. If your are replacing and existing drive simply remove it, and replace on the same IDE cable making sure the jumper is set to slave. Assuming you have one drive to the 0-IDE connector and the other connector is is to existing CD and this new drive is to be a second one. You will need another IDE ribbon cable. Set the drive to Master- connect the cale. position and fix the drive and plug the other end on the cable to the second IDE connector [Drive 01] See you mother board manual - connected a spere power connector.
May 18, 2007 | Samsung SD 608 (SD-608) Internal DVD Drive
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
