Question about Kenmore HE2 Plus Front Load Washer
Kenmore He 2 Plus washer door is locked and unable to open
Washer stopped with 3 minutes on timer on spin cycle. I was running the Normal/Casual wash. I tried the 2 suggestions in owners manual to run the RInse and Spin cycle and to push stop. The door locked red light stays on as well as the add garment light. When I push Start, there is a quiet buzz sound instead of the loud click. The door stays locked.
  • Laurel Westall
    Laurel Westall May 30, 2014
    Having the same problem myself. Have tried methods mentioned in manual without success and door remains locked whether machine is plugged in or not.
    Sergeant:
  • Kenmore Expert
  • 211 Answers
Unplug the washer an the door will open
Posted on Apr 25, 2010
  • djvts1 Oct 29, 2010
    tried this and it didn't work.
  • Dale
    Dale Dec 30, 2013
    does not work
2 Suggested Answers
cpldw48
  • 211 Answers
SOURCE: Kenmore He2 Plus front load
unplurg your washer an wait 5minute an the door will open
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
Replaced CCU, Sears washer still will not run
Suggestion: Unplug washer from mains. Open up the machine, disconnect and refit all connectors with wires one by one. Could be some loose connection somewhere. Also helps in the long run
Click if helped.
Mar 29, 2013 | Washing Machines
I was using the spin cycle to spin water from a scarf. I decided to stop the stop so I hit cancel button. Now the washer door is locked and I can't open it.
• If the cycle is interrupted during spin, it will take approximately 2-3 minutes for the door lock to release. DO NOT force open the door. • To stop the washer, press Cancel.
Jan 05, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a Kenmore washer HE2 plus and F26 is flashing
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
May 14, 2010 | Kenmore HE2 Plus Front Load Washer
What does error code F26 mean? The washer will fill with water, work for about 5 minutes and then post error F26 and stop working. Where do I find the error codes?
DOOR SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
May 05, 2010 | Kenmore HE2 Plus Front Load Washer
Our Kenmore HE2t reads F26 and stops running half way through cycle
DOOR SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Mar 09, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
1,289 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
