Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
What is the correct oil/gas mixture for Ryobi 31cc 15"
  • 54 Answers
I'm pretty sure it's 50:1 but checked with your local dealer to be sure.
Posted on Apr 26, 2010
Oil and gas mixture
Mixture is typically 40 or 50 to 1, gas to oil. The exact mix should be stamped on the gas cap.
Apr 10, 2010 | Ryobi 15" Electric Factory Reconditioned...
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
What is the ratio of gas and oil mix for a ryobi 31cc trimmer
just use about 3 to 4 ounces of 2 cycle oil per gallon and you should be fine. a little extra lubrication wont hurt it
May 18, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Gas oil mixture
Hello slabieniec:
The Newer 2 Cycle Trimmers use a 50:1 Ratio (OEM Suggested Ratio). I Use a 40:1 Ratio in Most of my Equipment, Except for Chainsaws and Hole Drillers/Augers. For the Chainsaws I Use a 32:1 Ratio and the Hole Digger/Auger Uses a 25:1 Ratio.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Ryobi Garden
My ryobi 31cc 15" 700r won't start
You need to push the primer button 10 times or so (the button at the top of the speed control) to get the gass pumped up into the system again. Likely gas not getting through the line yet. Takes awhile.
May 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Can't remember what fuel our Ryobi Lawn Hornet uses
All 2 cycle tools must have oil mixed with the gas. Use the proper oil and mixture recommend by the manufacture.
Dec 08, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 31cc lawn trimmer carb adjustment
As with all 2 strokes if you have compression and a reasonable spark, you only need fresh fuel with correct oil ratio) and they must go !(as long as you haven't fiddled first and all gaskets are sealing) I start mine by(1) pumping the primer till it is firm,(2) full choke,(3) pull till it kicks ONCE,(4) half choke, pull till it runs,allow to warm up and(5) switch to run (you may need to apply a bit of throttle while pulling as in (4)(or give it a few more pumps if it dies) If all is ok, check that when properly warmed up there is a smooth transition from idle to full revs, if it hesitates it may need the LOW SPEED mixture leaning (clockwise) SLIGHTLY.If it dies the LOW SPEED mixture may need richening(anti-clockwise)(adjust 1/8 turn at a time) Make sure that motor is just peaking at full revs and is on the RICH side of peaking (HIGH SPEED mixture)(this will avoid seizing it Adjust both till it revs cleanly and is JUST rich at full, and idleing nicely and it should start without too much trouble.(If you have fiddled and are lost,-about 2 1/2 turns out from closed on both needles should get you started)
Nov 23, 2008 | Garden
How do I connect the fuel lines on the Ryobi 31cc petrol edge trimmer.
I have a Ryobi 31cc 17inch cut with gas line problems and this answered my questions. Thank You
R Green
Oct 18, 2008 | Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
399 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
