Question about Maytag SDG4606A Gas Dryer
Heats for only 10 minutes the will not heat again
When dryer is initially started, the dryer will heat for about 10 minutes then the flame will go out. after about 20 seconds or so,the igniter will then heat up red hot for about 7 seconds then it will time out. It will do that again about 20 seconds or so later then will go out, and keeps doing that. The gas part is not activating when the igniter turns on when the dryer is calling for heat.
  • weber1166 Apr 28, 2010
    Ok... Part arrived and I replaced the igniter. Problem still exists.
    Sorry... and yes, it is a gas dryer
  • Maytag Master
  • 43,501 Answers
Your ignitor is going bad , Yes it sounds crazy, but this tip will explain further..
If you have a gas dryerHeats for only 10 minutes the will not heat again - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 25, 2010
Testimonial: "I have already ordered the part... Thank you!"
2 Suggested Answers
milten1
  • 1304 Answers
SOURCE: kenmore dryer, saw igniter heats up, seconds later
sounds like bad gas coils the hold or assist, but i would change them both at the same time
they are the lilttle cylinders on top of the gas valve
Posted on Oct 05, 2009
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
Dryer not heating
odess, sounds like you need a new set of coils for the valve. Easy job. Remove the bottom access panel and you will see the gas valve. Remove the top screws from the coils and the coils will lift off and then unplug the harnesses. Install the new coils. Part number for your coils is 12001349. Price about 18.00 Check them out at repairclinic.com This should take care of your heating issues. Catriver.
Oct 01, 2007 | Dryers
The dryer heats up at first but the burner won't ignite after it cycles off. The ignitor comes on but no flame. I changed the rear thermostat on the vent housing but that did not resolve the problem.
you have bad gas coils.when they are starting to die the dryer will run normally for the first 10 to 30 minutes and then no flame,the coils work fine until they heat up then nothing.when they cool down you'll have a flame again.easy fix,the coils are on top of the gas valve,take out the two phillips screws,remove the metal cover and change out the coils,that's it part number 279834.let me know how you make out
Jul 17, 2010 | Kenmore 74602 Gas Dryer
My Kenmore gas dryer only heats for short time. The burner comes on initially for about 1-2 minutes then cycles off. Later, the igniter turns on, but the burner does not come on. I have cleaned the...
if the dryer runs and heats for a short time and then no flame you have bad gas coils,when they are failing they work until they heat up and cut out,when they cool down the heat will work again for like the first 10 to 20 minutes and then cut out again.take out the two phillips screws on top of the gas valve,remove the top cover and change out the coils,check the coil with the three prongs on it or check the post you pull it off of,there should be a spacer on the post,if you don't see it on the post look in the hole of the coil,if it's in the coil poke it out and slide it back on the post,easy fix
Jun 12, 2010 | Kenmore Dryers
Gas dryer heats for 10 minutes then heat goes off
it's doing what it's supposed to do. you should use a different setting.
Sep 07, 2009 | Dryers
Dryer starts, heat up than the goes out
Faulty gas valve coils are the typical cause of this type of "cycling". These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves and permit the burner to light. If any gas valve coils are suspected of being faulty, it is recommended that both (all) be replaced at the same time. Hope this helped and best wishes.
Sep 02, 2009 | Dryers
Dryer flame on magtag wont stay lit. Pilot flares up but no flame
Thermocouple is probably bad. The pilot burns and heats a sensor which tells the CPU that the Flame can start, and the thermocouple heating up changes voltage with increase temperature and tells the CPU that the Flame is burning OK. If it is defective, there is no voltage change and the CPU assumes that the Flame didn't start for some reason, (Gas only!) and turns if off for safety. Over and over xx times.
My .02
Good Luck!
Mar 26, 2009 | Dryers
I have a gas Gas dryer with low heat. The igniter is good, the gas valve opens and I get a flame, but it never heats up past 89 degrees. I'm guessing there is a secondary gas valve or something that kicks...
if the vent line is blocked or lint is built up in the duct where the lint filter slides into the flame will only stay on for like 5 to 10 seconds or the gas coils are bad,when the coils are starting to fail you'll have heat for the first 10 to 15 minutes and then no heat,when the coils cool down they will work again,these are the two most common problems with a gas dryer,try removing the vent line from the back of dryer and run it to see if it heats any better if so you have a block in the vent line.or run the dryer for 15 minutes and look at the flame and see if it still ignites,if not the coils are bad.next time send the brand name and model number off of the dryer,open the door look around the opening where you put the clothes in and you'll see the model number good luck.if those two things check good you could have a bad cycling thermostat located on the blower wheel housing but i would check for a block in the pipe or lint filter duct.
Nov 29, 2017 | Maytag Neptune MDG5500AW Gas Dryer
Maytag SDG4606A Gas Dryer Logo
179 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
