Question about Whirlpool RF378LXKS Electric Kitchen Range
Whirlpool Electric Glass top stove takes a long time to heat up. Is it a problem with the element?
  • Whirlpool Master
  • 43,501 Answers
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 25, 2010
2 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: How do I raise the stove top of a ceramic glass mo...
Open the oven door and look up across the front for 4 screws.
Eric
Posted on May 23, 2010
My scholtse glass top won't work with my utencils
THe glass top is just that, glass! If the elements beneath it are not producing enough heat your utensils will not cook. Pull off the glass top by removing fasteners (either in the front of the stove or under the back panel of the stove). Then, turn on each electric burner to see if it turns RED hot. If not, wait till everything COOLS and reseat each heating elememt and retest those that failed. If that doesn't solve the problem, you can buy heating elements at Home Depot or other stores...
Nov 12, 2012 | Kitchen Ranges
Whirlpool electric oven not heating (has a functional stove top)
Hello Daniellel583! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Daniellel583), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool RF111PXS Electric Range
Whirlpool oven heating element
Are you trying to replace the stove top element, or oven element? For the stove top element, just lift up the side opposite where it plugs in and pull straight out.
The oven element usually have one or two screws holding a plate in near where the elements go into the back of the oven. Remove the screws and pull straight out. Reverse the procedure to install a new element. The top broil element will be secured in with a couple brackets to hold it up, these must be unscrewed, removed, and then pull the broil element out.
Remember to turn off power to the range before replacing any of the elements.
Aug 27, 2008 | Whirlpool RBS305PD Electric Single Oven
RF367LXKQ burner light always on
YOU HAVE A BAD STOVE SWITCH,TAKE THE TOP BACK PANEL OFF STOVE,HOW FIND OUT WHAT COLOR WIRES GO TO THE STOVE LIGHTS,NOW ONE SWITCH AT A TIME REMOVE THOSE WIRES CHECK TO SEE IF LIGHT GOES OUT NOT RECONNECT WIRES AND MOVE ON TO THE NEXT SWITCH UNTIL YOU FIND THE BAD ONE THE REPLACE IT,HOPE THIS HELPS-MIKE
May 30, 2008 | Whirlpool RF367 Electric Kitchen Range
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
Jan 19, 2008 | Kitchen Ranges
Whirlpool glass top stove
The glass top can be change, but be aware that if you have all your cooking element fixed togetter, this could cost plenty of $$$. If your heating element can be remove easyly, you are a lucky owner.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Mar 13, 2007 | Whirlpool RF365 Electric Kitchen Range
Whirlpool RF378LXKS Electric Kitchen Range Logo
252 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
