Question about Franklin Freezer Chef FIM70 Commercial Ice Maker
FIM90 spray head
I have cleaned this unit replaced the spray nozels and replaced the pump the problem is that it will spray water and start to make ice then the spray from the nozels peter out and just sees to circulate never spraying on the freezer unit it seems as though the pump is not working right. The old pump and the new one do the same thing.
On the other hand if you put it in cleaning mode it will spray all the time so I just can't figure it out.
  • 3 Answers
I had the same issue and replaced the control box. Mine is now making ice. The problem was a relay in the control box.
Posted on May 25, 2010
So what happens after checking the voltage??? I have the same problem and was about to replace the pump... what do I need to do to fix this lack of spray in the "ice making" process?
Posted on May 13, 2010
  • perdelt May 19, 2010
    OK. If the water bin is low during ice making, the spray is not strong. If I add water it sprays great... so- is the water inlet valve not working or is the controller not controlling it? When I first start the machine, I hear the click, and water flows into the top, but after it starts making ice there isn't enough water to spray correctly. What do you think??
  • Franklin Master
  • 3,361 Answers
Attach a volt meter to the pump wire terminals and check for voltage fluctuations while in the freeze mode.
Posted on Apr 25, 2010
  • steve
    steve May 13, 2010
    Simply verify the pump has correct voltage and the pump is running.
    Next make sure the pump impeller is pumping water.
    Third make sure the water lines and nozzle is not restricted.
Water is leaking out drain during cycling; cubes are thinner than normal. Does water valve need to be replaced or check rubber gasket?
Just above the pump there is a check valve that may be stuck open
during operation which will cause thin ice. Also make sure you have the o-ring on the bottom of the drain tube if it was removed during cleaning.
May 20, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Vapor coming from bottom of inside freezer and water to dispenser frozen
The most common cause of this is a dirty condenser coil. Find the condenser coil for the unit , it will be under the freezer, in the back or ,in some models, on top. It will have a fan behind it. Shut of the unit and clean it. First with a paint brush to remove heavy dirt, then with a spray coil cleaner--this may get dirty, so be prepared with a mop. Clean it thoroughly without getting electrical components wet. (If you get anything electrical wet, make sure you allow ample time to dry before energizing it).
Mar 27, 2014 | Freezers
Hoshizaki Model KM500MAH
When first turned on, the sump should fill with water. If it does, water solenoid is good. If you have a full sump, and no water pump running, sometimes the "Ice/Off/Wash" switch is bad. Put switch in wash, if pump runs, it's good. Now put in Ice position, if sump fills and pump does not come on and compressor indicates it is in the freeze cycle, replace that switch first. Simplest place to start and lest costly to fix.
Oct 04, 2017 | Hoshizaki Freezers
Its not making ice anymore
You will need to replace the "defrost thermostat" on the unit. Here is the kit to order.
Nov 18, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Not making ice
check for a stuck float switch. located near the water pump. Usually white plastic with a tube on top and a black boot at the bottom. Tap on it lightly while unit is filling with water. If that works, you need to disasseble and clean.
Sep 30, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki water dont stop runing
float switch is stuck in the "down" position. The unit goes thru a fill cycle and after 1 minute, the board "Looks" at the float swith to "see" if the sump is full. If float is stuck down, it tells the board that the unit does not have enough water and stays in the fill cycle. The compressor will not come on as long as the machine "thinks" there is not enough water. let me know if I can help further
Aug 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I had some meat go bad in my freezer. I've cleaned and cleaned with hot water, dish soap, bleach, vanilla extract, oxyclean, and just now tried vinegar, next I will try squeezing lemon and/or placing...
just spray it with 75/25 bleach/water it will kill any germs/smells....
also syringe the drain hole with bleach.(you only needed to wash out with clorine bleach and let it dry to totally clean the unit....)
Jul 30, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Our FIM90 will not make ice. it worked when we got it and since then only produces cold water
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 11, 2010 | Franklin Freezer Chef FIM70 Commercial Ice...
Ice machine is only making flakey size ice. Machine is clean and filters have been changed. Water is flowing and cold; it appears that the machine is in constant operation.
sounds like there is a problem with the water in the sump escaping. Sometimes, the plastic grate under the evap plates break and pieces get stuck in the dump valve. It is a triangular piece that the pump attaches to via a hose. It is spring loaded and the pieces prevent it from seating, thus, water leaks into the drain that you will not notice. When the water level in the sump gets low enough, it goes into a harvest and drops small slivers of ice. I'd check that out first.
Hope this helps.
Feb 09, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Unit not coming on
Start out by putting the power switch in the "Wash" position. If pump motor comes on, but unit does not run in "Ice" position, more times than not, it's the power switch. If nothing happens in the "Wash" position, check the bin t'stat. It's probably open and not letting power go through it.
Good Luck and hope this works. Get back to me if it doesn't and we'll go a little further. Please get serial number too.
Oct 02, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Franklin Freezer Chef FIM70 Commercial Ice Maker Logo
166 people viewed this question
Top Franklin Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
mike cooper
Are you a Franklin Freezer Expert? Answer questions, earn points and help others
