Question about Vector VEC024B MAXX SST Power Inverter
I tried to run a heavy load and now the inverter won't work. The green light is on but no juice in the outlets.  Is there a fuse?  Is it toast?
  • 3,051 Answers
Hello there:
The power inverter can handle only certain loads and if too much is applied than the inverter will pop and this is what it sounds like happned so wht you cna do is to either buy a new inverter part from the manufacture or send the unit back if you still have the warranty.
Normally they stand behind their product and will repair it for free ok
Hope this is very helpful for you
Best regards Michael
Posted on Apr 24, 2010
I have a '97 Subaru Outback Legacy that has a problem with cigarette lighter/dc outlet. The outlet works fine when using the lighter. The lighter heats up and turns red. However, when using a char
You can purchase a specific charging socket extension at most car accessory outlets. It can be wired to the car's battery, or as an extension of another heavy load circuit such as the cigarette lighter and this is a very inexpensive item and is reasonably easy to instal.
Nov 01, 2012 | 1997 Subaru Outback
HP printer won't print
Hi Kathy,
What is the printer model ? Try the step below.
While the printer has power, Disconnect the power cable from back of the printer. Wait for 10 seconds and reconnect. This should fix the issue.
If this does not, try changing the wall socket. If you have connected it to Surge protector, Try connecting to Wall outlet directly.
Hope this will fix the issue.
Regards,
Sean
Aug 10, 2012 | Office Equipment & Supplies
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
Apex 4100i nordic track treadmill.
Check the fuses on the motor control board, under the lower hood. There are usually 2 of them, and they are ceramic so you need to test them for continuity with a meter or test light/ buzzer. One is usually 10 amps the other is usually 15 amps.
These will blow when the treadmill is used on an electrical circuit that is inadequate for the mill. The way many houses are wired today leads to this issue. You can trip the reaker int he box so the affected branch is no longer energized and follow the wiring- at each outlet, remove the cover, and look to see if the wires are just stabbed into the back of the outlets. While this is acceptable for code, it is not acceptable for loads like a treadmill. Most of the time the wires cannot be extracted without damaging the outlet, so get enough outlets for the run, and with the new outlets, make sure to attach the wires under the screw heads. Black (sometimes red) to brass screws and white to silvery screws. and make sure the ground wire is attached to the green grounding screw. If you would rather an electrician do it- that is a good idea, and make sure they put the wire under the screw heads,. Form a loop in the wire clockwise as this is the direction the screw tightens, if the loop is clockwise it will stay under the screw head.
While this may not eliminate the problem of fuses blowing in all cases- in those remaining cases heavier wire must be run to the outlet the treadmill is plugged into.
Jan 24, 2012 | Exercise & Fitness
LG Washer WM2277HW wont turn on what can I do?
I would try plugging it into a different self dedicated outlet. It also might be the internal plug connection. Use a heavy duty extension cord to see if it works off a different circuit.
Jan 23, 2012 | LG WM-2277HW Front Load Washer
Hi there, I have a 2005 ford f350 dually and was changing a fuse for the outside driver side back wheel panel lights that won't turn on, found the blown fuse but still no luck. So started checking all...
Start out by tracing down that wire that runs to it. Take a test light and see if your getting juice to it. if your not it sounds like you may have a broke or grounded out wire. Try that as a first test . It could be that simple.
Oct 15, 2011 | 2005 Ford F 350 Super Duty
Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
Sep 14, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
I have a xantrex xplus 400. The power and fault led light up as soon as it is plugged in with no ac output.
If you have a load that is more than this inverter will take it will not output anything. Try just a light bulb if this does not work then the output if fried or the output fuse/breaker if it has one is blown.
Feb 16, 2010 | Xantrex Technology DC to Dual-Outlet AC...
Power inverter blows fuse in car
overloading fuse on cars wiring try direct connection to battery
Dec 27, 2008 | Audiovox Jensen Jp 20 Single Outlet 160...
No power at the power outlet
if from the outlet had power before and you used a test light to test for power . remove the barrel ( the front part of the lighter) in the dash using your thumb to turn it.On some vehicles they have an inline fuse not to far from the cig. lighter on the inside of the dash
Dec 19, 2008 | 2005 GMC Sierra 2500HD 4WD
Vector VEC024B MAXX SST Power Inverter Logo
206 people viewed this question
Top Vector Electronics - Others Experts
Craig Butler
Craig Butler
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
