Question about Garden
I have a Homelite Ranger chain saw with a 33cc engine. Went to push the bulb for the fuel prime and the bulb stayed stuck in. Is there anyway to get the bulb to come back out or do I have to buy a new one?
    President:
  • 2,220 Answers
It is not a primer, it is an air bleeder.
Disconnect the fuel filter and try it, If the filter is partly blocked that might do it. Fuel is drawn from the tank through the carburetor when the bulb is released a plugged filter or kinked/collapsed line is the likely cause.
A severly plugged tank vent is a distant possibility too. Try it with the cap off.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 25, 2010
  • 57 Answers
Open up your gas cap and poke it a few times. It just stayed in because of the vacuum inside it, nothing wrong with the bulb. It just needs to get the flow going again.
Posted on Apr 24, 2010
Homelite chain saw csp 3314 will start if i tip petrol in spark plug home but wont stay running
There could be a problem with either the fuel line going to the carb or the impulse line that's connected from the cylinder base that generates the 'pulsing' action that operates the diaphragm fuel pump. Today's alcohol rich gasoline has a tendency to weaken or even rot the rubber lines causing fuel delivery issues.
If you don't use your saw for extended periods, dump the tank empty then start the engine and run the residual gasoline from the line. This will help extend the life of the fuel lines.
Another possibility could be a blocked fuel filter, but that is remote.
Feb 22, 2015 | Homelite 12" Oregon Chain Saw Repl. Chain...
My chain saw 14" homelite
primers pull fuel from the carb and dumps it back into the tank, so if the bulb will not prime the chances are the fuel filter in the tank is blocked, pull the fuel hose through the filer hole and replace the filter on the end.
Jan 27, 2011 | Garden
Just got a homelite 33cc 14 inch chain saw, do you mix gas and oil on this chain saw?
Yes you do! The ratio is 50:1 fuel to oil. Be sure to use a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Be sure to use fresh fuel and mix the two in it's own container. Be sure to shake the container thoroughly each time just before refueling to prevent oil starvation in the engine. Don't make up more than one gallon at a time unless sawing is your business. Hope this helps!
Dec 15, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
What is the mix for my Homelite 16" 33cc chainsaw?
50:1 is the fuel to oil ratio. Never use petroleum oil (engine or boat motor oil). Always use a synthetic saw oil available from home centers, hardware stores and saw dealers. The bottles are usually graduated to various ratios for a gallon of fresh gas. Always premix in it's own container and shake the container thoroughly each time just before filling the tank to prevent oil starvation. Be sure to use bar/chain oil for the chain as well, and keep the chain sharp and well adjusted. Hope this helps!
Nov 14, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
What is the oil to gas ratio for a homelite zr 10926 16 chain saw
This is a current Homelite product although not your saw. This clearly recommends 50:1 as do I. I find no OM for your saw, a "Ranger 33cc 16" Chain Saw UT-10926"
http://www.homelite.com/product_manual/file_url/66/UT10540_60_80_QSG.pdf
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1 and have for a number of years.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
I suggest you contact Homelite and request an OM for your saw.
Homelite/Ryobi.com (Contact Us)
https://register.homelite.com/contact_us/new
Please ask they prove a link to a site where ALL homelite product OMs may be accessed.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
May 06, 2010 | Homelite ZR10926 16 Chain Saw
HOMELITE CHAIN SAWS LOOKING for a parts manual to repair and replace damage parts. model ut109470 33cc family 4hcps0384aa sin #AGO780395-03-4 Can you help
Go to: http://hcpi.arinet.com/scripts/EmpartISAPI.dll?MF&app=HNL531&...
This gets you to drawings and part numbers of the entire saw. Also, for an excellent article on the Walbro carburetor, go to: http://www.drystacked.com Hope this helps!
May 02, 2010 | Homelite ZR10926 16 Chain Saw
Jambed brake
Hello Brian; Why do you want to? You may never get it back together. The IPL is probably as good an illustration as you will find. Enlarge it enough to make the detail visible. There is a chain brake kit available that might include some instructions but no promises (brake dragging? try changing the clutch bearing). This is as detailed as it gets. Contact Homelite and they will likely tell you to take to a service center.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here. cursor down to "Ranger 33cc 16" Chain Saw UT-10926". "Clutch - Hand Guard - Drive Case Cover" detail.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Where can i buy a replacement chain for the expand-it prunner emmanuel1942@yahoo.com
Lawnmower, Small Engine and Outdoor Power Parts from M&D - Site ...sacore:green.gif UP08688: UP08688 UP08688 HOMELITE PART UP08688 Replaced by: 6958301 > PS03873 CHAIN,3/8,.043,10 .... HOMELITE PART UT41002A19/UT41002A-19 KNOB FOR EXPAND-IT COUPLER ... ZR10926: ZR10926 ZR10926 HOMELITE PART ZR10926 Chain Saw 16" Ranger 33CC ... ZR15520: ZR15520 ZR15520 HOMELITE PART ZR15520 Pruner Attachment ...
www.m-and-d.com/siteindex476.html - Cached - Similar
Mar 26, 2010 | Homelite Expand - It 10" Pruner Attachment
My Homelite Ranger 16 inch chainsaw starts great runs smooth but upon cutting in to any sized branch or tree it now bogs down and stops cutting. Whats strange is that doesn't die it keeps running but will...
My 16" Ranger had the same problem. Here's how to fix it. Take off the top cover and the red side cover to acess the carburator. Take the top off the carb; there is a single screw that holds it on. Inside you will see a 10mm round indention. This is a final screen fuel filter. Mine had a layer of light brown dirt over the screen. Take a small screwdriver and carefully scrape the dirt off. You don't need to clean the carb any further or adjust the H and L settings or anything. Put it back together and it should run with no bogging. down.
Mar 20, 2010 | Homelite ZR10926 16 Chain Saw
Garden Logo
166 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
