Question about Onkyo TX-SR503 Receiver
When i push the button to increase volume it goes from where it is to full volume. When i push the remote volume down it goes all the way down. If i use the knob on the receiver it is fine.
    Champion:
  • 287 Answers
It sounds like you have sticky remote control buttons. take the remote apart and clean it.
Posted on Apr 24, 2010
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
No volume
Look on remote to see if there is one button labeled "mute." If so push that when tv is on and see if that fixes sound. Or find volume buttons on tv and hold down button that is for increasing sound, should show a scale on screen with volume increasing.
Jan 15, 2011 | Toshiba MD20FM1 20 in. TV/DVD Combo
Volume turns up or down on its own
yes direct into the buttons the WD40 is the best thing i've ever seen, that will not damage anything you can spray it without fear and then try to activate the buttons a few times, of course with the tv off.
May 20, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Soyo Flat Screen TV Sound or Volume control is stuck
Hi deborah card, Lets first make sure your remote is not causing your problem, Look at the light (led) on the remote, is it lit and pulsing? If not you are having a problem with the control panel,  Have you recently cleaned your tv with a liquid? If so you will need to dry the panel with a hairdryer, unplug the power from the tv, put it on low heat and hold it about 6 inches from the panel for a few minutes. With the tv still unpluged press all buttons on the panel a few times then plug back in and try it.  Let me know if this helps and please rate this solution.   lone99star
Jan 11, 2009 | Soyo DYLT032D 32 in. LCD Television
Controls
Someone push the volume up button too hard and is stuck,this also has the micro(brain) confused,all this happen before you fund out your remote would not work.
Sep 03, 2006 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Volume goes up on its own and stays up.
Aren you sure that the volume up button is not stuck in . It should feel just like the rest of them A little click? It could still be shorted,or the capacitor across the switch could be defective. If all this seems good then the eeprom, or the microprocessor,or the line or trace going to the volum button could be shorted. This is not a repair you should attempt unless your a tech. Now the button thong can be looked at after the set is unpluged and the back is off, gently slide out the chassis toward the rear of the set just a little and slide it back to see if the button is released. if that dosent help then you will need to take the set to The repair center. Good Luck
Jun 10, 2006 | RCA F31672ET TV
Onkyo TX-SR503 Receiver Logo
147 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
