Question about Philips SA5125/37 MP3 Player
Still gay O.K. My philips Go-gear SA51xx is still being gay.. I repaired it and everything, so now it recognizes on the computer cool and i can put music and everything on it. I listened to it for a half hour maybe. Then i shut it off. i went to listen to it again but it wont turn on. Sometimes it will go to the "go-gear" screen but then shut off. i tried repairing again but it did not work. does anyone have any information to help me? if so... PLEASE HELP!!!
  • R2ro Mar 26, 2008
    i tried to reset it but nothing happens please advice what to do
  • Daryn Jacobs Apr 03, 2008
    the lock on this model is a button that only activates when on..
Did you check the side to make sure you didn't have it locked up
Posted on Mar 31, 2008
I have a philips go gear cam i plugged it into my computer one day and then i unplugged it it deleted everything and when i try and do anything with it it says i have no memory on the device at all and in...
If the problem persists, try to restore the factory settings with the Philips Device Manager.
You can download the Philips Device Manager software from the Software and drivers section on www.philips.com/support.
You can also repair it using Device Manager. Here is how:
Launch Device Manager and click the Tool menu and select "Repair", then follow the instructions to perform the repair process. Make sure all other applications such as Philips Plug-in, Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device.
Unfortunately, the contents will be removed, so its always suggested to keep a back up of all the data on your computer.
Hope this helps.
Feb 26, 2011 | Philips GoGear Flash MP3 Player
Tip
The Philips GO-Gear unit is got stuck frozen?
Make sure the hol/lock is not engaged. As logn as it's not engaged, run the Repair in Philips Device Manager. If the Device Manager will not recognize the player: Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off.Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab.Reset the player one more time while connected to computer. Follow the repair instructions. This will help.Good luck.
on Mar 05, 2010 | Televison & Video
I have a Go-Gear MP3 4GB player,where can I get a user manual/instructions
i can help you with this go gear mp3 4gb phillips pmc7230 SA51XX SA60XX SA93XX just let me know wich one you need help and i will help you and pls rate my help.
Feb 06, 2010 | Philips Audio Players & Recorders
My mp4 player is not being recognized
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Mar 15, 2009 | Philips GOGEAR SA6045 MP3 Player
Repairing it
Get the updated version of the Device Manager from Philips website, and THEN run the repair. If your PC isn't recognizing the device, a normal repair is hard to do, so you have to follow my bootleg instructions:
-Tha Mp3 Doctor
Jan 09, 2009 | Philips SA3025/37 Flash MP3 Player
Good morning, my go gear is stuck, it will not allow me to operate any of the buttons. It just stay on one screen, and the computer does not recognize the go gear Hello. I'm having the same problem with...
Make sure the hol/lock is not engaged. As logn as it's not engaged, run the Repair in Philips Device Manager. If the Device Manager will not recognize the player: Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
Jan 06, 2009 | Audio Players & Recorders
It won't connect to my PC, says driver not found
If the volume + method didn't work, then there is some feature about your PC config that is not going to work with this player. you can try the FAQ method on Philips website for when the PC is not recognizing the player, but I've never seen a case where it was successful.
Jul 28, 2008 | Philips SA5125/37 MP3 Player
Sa51xx go gear
Recovery mode - disconnect player from computer, turn off player, hold in volume +, reconnect player to computer while holding volume +, continue holding volume + for up to a minute until Found New Hardware Wizard pops up
May 13, 2008 | Philips SA5125/37 MP3 Player
Memory corruption
My mp3 player Philip SA51xx 2gb says "memory corruption please repair it now" can I ask your hepl to fix the problem thank you
Dec 24, 2007 | Philips SA5125/37 MP3 Player
Philips SA5125/37 MP3 Player Logo
104 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
