Question about Probasics Rite-Neb Mini Compressor Nebulizer
My nebulizer isn't producing steam what is wrong? The air is working, I can hear the machine going but no steam is being produced.
  • Anonymous Apr 18, 2016
    It's probably missing the baffle piece that's supposed to be placed inside the medicine cup. It must have fallen out. Check the booklet to see what the baffle piece look like. Good luck.
  • 31 Answers
Most likely the disposable neb kit is bad or put together incorrectly.
Posted on Jun 27, 2010
Where is filter to clean on neb. Air flow present. But, tubing popping off and not enough airflow to produce proper steam and med inhalr. Did check tubing and chamber. Both new. Any suggestions?
May be defective nebulizer, or may need diffuser reinstalled. Inside bottom of neb cup (unscrew top half) is small plastic piece (diffuser) that mounts directly over the hose connector (on outside) U can pull the plastic piece up to make sure its not too tight ,can come out-just push back on- or push down if too loose (poor air flow stream) If the diffuser is lost or broken you need a new nebulizer. If home care company wants to charge you more, tell them they gave you a defective nebulizer. Im a retired RRT
Feb 08, 2018 | Medical
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
X5 steam cleaner does not pump steam
Hey Shaun, I only bought mine a little over 12 months ago and the same thing has happened with little than average use. I got in contact with the company who sold it to me. They suggested I buy the hand held part and that was it. How ****. I'm going to use a household descaler
Apr 23, 2013 | Thane Distribution Group H20 X5 5-in-1...
Saeco vienna super automatica coffe maker produces very little coffee and it comes out very slow.
sounds like your pump. When you turn steam knob on, you should hear the pump go bump,bump,bump. When hot water is turned on, you should hear pump run steady.
Jan 07, 2013 | Saeco Vienna SuperAutomatica Coffee...
My nebulizer isn't producing steam what is wrong, it was working and then it just stop working in the middle of doing a treatment.
hello
Its due to any hurdle inside the motor. If you know some engineerring then...
1. unscrew the back of the cover
2.there are two pipes attached to the motor. check either there is anything that press the pipe to stop flow or not.
3. if so carefully remove that.
and
if it is in warranty then without opening it take it to the supplier for servicing.
NOTE: never try it to open if it is in warrenty.
regards
Feb 28, 2011 | Mini Plus Nebulizer/Compressor 5 YR...
My nonebulizer machine not producing steam
Please let me know make and model. Is it old and have you used it before?
Jan 03, 2010 | Health & Beauty
Doesn't produce steam for more than 1 minute.
You should not have your steam wand on for more than a minute.
Jun 29, 2009 | Gaggia Carezza Espresso Machine
Humidifer not working
If the machine actually turns on and you can hear it working your filter is probably plugged. The filter is usually a white cotton plug looking thing located somewhere near the tubing port. Locate the filter it will pull straight out or screw out. You should have a replacement filter in the box the machine came in or should be able to order extras from the company
Dec 14, 2008 | DeVilbiss Pulmo Aide Compressor Nebulizer
Nebulizers problem
There are two main types of nebulizers: jet and ultrasonic devices. Jet nebulizers form droplets by using a compressor to deliver a pressurized jet stream of air down a narrow tube and through an opening. This creates a vacuum (through the Venturi effect), thus drawing liquid from a reservoir. The resultant small droplets of liquid are propelled out of the machine by the continued jet stream. Ultrasonic nebulizers produce aerosolized droplets using high-frequency sound waves generated by a special crystal. Liquid drug is usually delivered to the crystal, where it forms a thin layer. Electricity excites the crystals, causing them to vibrate at extremely high frequency. This vibration forces the thin liquid layer through an adjacent mesh, creating a fine mist. Droplet size varies with the frequency of the sound waves created by the vibrating crystals.
Aug 27, 2008 | Cardinal Airlife Brand Modudose 5 Ml Unit...
Probasics Rite-Neb Mini Compressor Nebulizer Logo
2,385 people viewed this question
Top Probasics Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
ray gallant
Are you a Probasics Health and Beauty Expert? Answer questions, earn points and help others
