Finished copies on my Brother MFC-9700 not feeding through completely, stalling about a half-inch from the point where they trip the relay. Next sheet, of course, jams.
  • Jeff4653 Apr 25, 2010
    Appreciate your advice. I think my ancient printer has finally bit the dust. I tried the power recycle and the Print Spooler shutdown, but neither affects the problem, which takes place both when I print a document from the computer and when I use the MFC as a copier. It's clearly a physical problem, not a driver problem, as you predicted, and it's time to swap out the old guy.
    Again, many thanks!
    President:
  • 2,923 Answers
Here are the things that you need to do:
1. Power cycle the printer - disconnect the printer from the computer and from the wall socket for 5 minutes. Then plug it back in.
2. Restart the Print Spooler - click Start > Run or Search > type "services.msc" (without quotes) > hit Enter.
- Locate and click the Print Spooler > click "Stop the service", then after 15 seconds, click on "Restart the service".
3. If same problem occur, uninstall and reinstall the printer driver. Might as well, install the printer into different computer to see if it will do the same thing.
4. If same problem on different computer, you need to contact the manufacturer and have them check if there's a hardware problem on the printer.
Thank you and good luck!
Posted on Apr 24, 2010
  • Melvin Ramos
    Melvin Ramos Apr 25, 2010
    You are welcome!
    Thank you for using fixya
Brother mfc 9700 keeps jamming
Hi, maibe it is the cartidge, the pinions not working. Pull out the toner cartridge and replace with another, if you have. If not you must try to rotate the cilinder and see if work.
Sep 14, 2012 | Brother MFC 9700 All-In-One Laser Printer
Copies do not print properly
Have you tried to reset the printer to factory defaults? possibly a internal software problem if everything else works fine, have you tried to scan a document to your pc?
there may be a firmware update available.
Jul 21, 2008 | Brother MFC 9700 All-In-One Laser Printer
Need to know how to change my Brother MFC 9700 printer from manual feed to automatic feed
Press the paper casette selector button,or select the calculator paper tray positions.
Dec 10, 2009 | Office Equipment & Supplies
I need to resend busy faxes with my MFC 9700
Yes, scroll through the set-up menus and set Number of Redials
Mar 06, 2009 | Brother MFC 9700 All-In-One Laser Printer
Brother mfc-9700 buttons quit working.
make sure you don't have a button stuck in the down position. it will lock up control panel. if all else fails, try unplugging for a couple of minutes.
hth,
razors
Feb 25, 2009 | Brother MFC 9700 All-In-One Laser Printer
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
How to photocopy?
Unfortunately, the Brother 9700 is not a "duplex" printer, meaning is does not print/scan/copy both sides of the paper. There is no way to solve this problem, other than to buy a new, duplex printer. Sorry!
May 22, 2008 | Brother MFC 9700 All-In-One Laser Printer
Brother MFC 9700
Remove your drum unit and you will see on top of where the drum unit sits inside your machine is a piece of glass(inside the machine). Wipe the glass with a soft dry cloth. If this do not work, remove your toner cartridge and see if the toner is spread evenly on the cartridge.
Mar 17, 2008 | Brother MFC 9700 All-In-One Laser Printer
15 people viewed this question
k24674
jasbo
jasbo
